Perkins Diesel Cold Start Problem
/ Perkins Diesel Cold Start Problem #1
wa5vpo
I just purchased a used ASV R-50 CTL with a Perkins DIesel 4 Cyl engine. It has about 1900 hours on it. When the outside temp is 60 degrees or above it starts in about 1 or 2 revolutions of the engine. If the temp is below 60 degrees, it takes 30 to 60 seconds or more before it will start. I got it from South Texas and I am afraid when it gets really cold here in Oklahoma, it won't ever start without burning up the starter. I have checked out the glow plugs and they seem OK. Any ideas on what the problem is? It appears to be firing during the start up process but just won't fire enough to keep running without the starter helping it.
Thanks for any ideas on what to look for.
/ Perkins Diesel Cold Start Problem #2
Could be timing, faulty injectors or most likely low compression. Ken Sweet
/ Perkins Diesel Cold Start Problem #3
How did you check the plugs, at 1900 hours I would suspect that they are done for?
Did you check all the wiring in the plug system for good clean contacts, what is the amp draw, how long are you heating the plugs?
I didn't check the plugs myself, I had a local dealer check them. He said they were heating ok. I had been heating them for 6 seconds according to the ASV manual but the dealer tech said I should be heating them for at least 20 seconds. That didn't seem to make any difference in how fast it started.
/ Perkins Diesel Cold Start Problem #5
Where plugs on tractor when checked - or did you remove them and take to dealer? If the latter, check the wiring to the plugs, as can affect if worn / bad connection.
Otherwise, check the ponts Ken Sweet mentions - on a perkins engine I'd agree that compression would be my #1 guess!
The plugs were on the machine when the dealer tested them. Unfortunately it was a hot day when he had the machine and couldn't reproduce the problem. Looks like I may have to take it back to them this fall when it cools down. Its over 100 here in OK now and it starts just fine and runs like a purring kitten.
Thanks again for your ideas.
/ Perkins Diesel Cold Start Problem #7
I will go with the glow plug theory. You can test the plug operation easily with an ammeter (initial 20 amps nominal for all four) or individually with an ohmeter.
Is there a record of how often, and when, the air filter was changed?
/ Perkins Diesel Cold Start Problem #8
Hi Bob, agreed, test each plug individually for its current draw and record the results. each plug should draw 5 amps each.
Mike, S.
Stated the second round of chemo today, all the numbers were checked and checked again.
/ Perkins Diesel Cold Start Problem #9
Best way to check the plugs is to take them out and test between the batt poles
1900 hrs is just broke in.
/ Perkins Diesel Cold Start Problem #10
Or just worn out. Depends on responsible ownership and maintenance practices. You would be amazed at how quickly you can trash a modern diesel through shoddy maintenance - ESPECIALLY THE AIR FILTER!
/ Perkins Diesel Cold Start Problem #12
Make sure there are enough amps available for the starter. Slow spinning starter will have similar effect.
This machine was owned by a rental company and it appears they gave it regular maintenance. The oil and hydraulic filters had dates marked on them as Nov. 2010 and 1908 hours. When I got the machine it was showing 1916 hours. I assume it was probably setting on the dealers lot from Nov. until I purchased it. I pulled the air filter and it looked clean. I couldn't blow any dust out with compressed air. It cranks over quite fast at 50 degrees but it won't fire enough to keep running. It has a new battery and alternator in it. I was wondering if there was any particular part of the engine I could heat up with an electric heater that would indicate what the problem was if it started after I heated up that part. Just a thought on how to troubleshoot the problem.
Thanks again for all the help.
/ Perkins Diesel Cold Start Problem #14
Wa5vpo, I would think the phrase Charging Voltage would say it all.
As for Bisons suggestion I can see his point, however I am not comfortable doing it that way.
Depending on how the plugs are installed in the engine, screw in or press fit with a yoke, there is a risk of breaking the plug in the engine.
Re-installing the plugs, everything must be clean, maybe new copper sealing washers, if not you could have a compression leak.
As for testing the plugs at the battery terminals, the plug tip will get RED HOT, you will need 14 Ga wire for the current and the body of the plug must contact the battery terminal NEVER the hot tip.
Good points by all. I think I will ask the tech next time I talk to him how he tested the plugs. I can do the current measurement if the tech didn't do that. It just seems strange to me that there can be so much difference between 65 degrees and 50 degrees in temp. My old Yanmar 3 cyl diesel doesn't ever have any starting problems until it gets down around 10 degrees and then that is typically a turn over problem due to the thick oil and or low battery voltage. It just wont' crank as fast as it does when it is warmer. I can understand that one. This magic temp region of 60 to 50 degrees has me scratching my head. I would never had suspected a problem like that.
Thanks again for all the help. With all our combined knowledge I am sure we will finally solve the problem.
/ Perkins Diesel Cold Start Problem #16
Hmm, you may want to consider looking into the starter motor. If it was assembled with thick grease that would definitely hold it back in colder weather. Also, the starter solenoid operator (piston / slug) should be lubricated with liquid graphite, not grease or oil.
Bob,
It appears that it turns over just as fast at 50 degrees as it does at 90 degrees, it just won't fire enough to start running on its own. That is what has me puzzled. All engines I have ever owned would always start if you could get them to crank fast enough. This one doesn't seem to be dependent upon crank speed, just the outside air temp. That is why I am sure it won't start at all when the temp gets cold enough to slow down the cranking speed.
Thanks again.
/ Perkins Diesel Cold Start Problem #18
Come to think of it, what engine oil are you using, 15W40 is typical, however it is much easer to start on 10W40 or a 5W40, all will give the same hot weather protection of 110-120 deg. Some owners use a electric mag base oil pan heater on the oil pan or the starter motor in the winter.
Not much to do but stay in bed, look at TV and see what is going on online, got to go and eat now, this chemo is kicking my butt.
Transit,
Not sure what oil is in it now. I was planning on 10W40 when I change it. That oil pan heater sounds like something I need to look into before winter. I think if I can solve the 50 degree starting problem then all I have to worry about is proper cranking speed during the real cold weather, ie. below 20 degrees. An oil pan heater should solve that one. I keep a battery minder on the battery at all times so it is always fully charged.
Enjoy your lunch and good luck with the chemo.
Thanks again.
/ Perkins Diesel Cold Start Problem #20
i may have missed it but I might check amps inline to each plug.. see what it is drawing.
soundguy
2025 78in. Hydraulic Dual Cylinder Rock Grapple Skid Steer Attachment (A61572)
2025 78in...
2017 Hino 155 16ft. Box Truck (A61573)
2017 Hino 155...
3PT TINE RAKE (A63291)
2025 Swict 72in. Bucket Skid Steer Attachment (A61572)
2025 Swict 72in...
2022 EZ-GO ELITE...
2014 John Deere 7230R Tractor (A63111)
2014 John Deere...
