NH TC35 weak hydraulics when hot
   / NH TC35 weak hydraulics when hot #1
newlife
Member
Maine
New Holland TC35
My TC35 has weak hydraulics when hot, fine when cold. It has only 450 hours on it so I would hope the pump is not warn at only 450 hours. Anyone had any simililar problem on a TC35,40 or 45 gear tractor?
   / NH TC35 weak hydraulics when hot #2
have you changed your hydro filters.they could be stopped up an not letting the oil flow like it should.thus making it get hot an stop working after awhile.
   / NH TC35 weak hydraulics when hot #3
I'm with bigbull,
have you done you scheduled P.M's on your tractor? As I would start there.
DevilDog
I'm with bigbull,
DevilDog
Yes the filter and the hydraulic fluid were changed less than 50 hours ago.
   / NH TC35 weak hydraulics when hot #5
You cannot make an objective qualitative judgement of your hydraulic performance without a pressure test. Do you have a loader where you could put a pressure gage at the quick connects? How are you judging your hydraulics? Does it lift something on the 3PH when cold, but not when hot? Is the loader weak? You've GOT to know the pressure. No responsible tech would adjust your pressure without testing it first.
   / NH TC35 weak hydraulics when hot #6
Without seeing your machine, problems when hot typically boil down to something having excess clearance and internal leaks. Perhaps an O-ring failing in the valve, the pump is worn out, a cylinder is leaking/bypassing inside, etc.
You can't diagnose this sort of problem without finding out what pressure the system is putting out under load.
   / NH TC35 weak hydraulics when hot #7
Pressure, pressure. It's half the equation, and even when the flow is going to sleep, your relief pressure is probably being maintained. A full-blown pressure/flow test is indicated. That said, clean oil, fresh filters and diminished performance as the oil temp increases more often than not indicates a worn pump. And no, pump failures are not typical of Nh TC Class III CUT's.
   / NH TC35 weak hydraulics when hot #8
:drink:........Here, Here.....Right on RickB......
Kubota Flow/Load Meter Test - Tractor Videos - Kubota, John Deere, New Holland and More
I don't mean to wear it out but that's exactly the step I'd take before going on to anything else.......
   / NH TC35 weak hydraulics when hot #9
RickB, I guess you see "weak" as meaning slow. To me, weak means it doesn't have the power to lift at any speed. If the relief pressure was being met, would the hydraulics be weak or slow? I agree completely that a full pressure-flow test is indicated, but I would still like to know how newlife defines "weak."
   / NH TC35 weak hydraulics when hot #10
Weak is often slow, as a partial load in the loader or on the hitch makes the system develop less than relief pressure.
Better to ask the OP what he means by 'weak' than to ask me.
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
20 STEEL FLAT SHEETS (A50854)
20 STEEL FLAT...
2019 Komatsu PC490LC-11 Hydraulic Excavator (A49461)
2019 Komatsu...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
