Pole Barn Build, 40x50x12
   / Pole Barn Build, 40x50x12
Well, we have not been able to get a lot done lately. Busy schedule but hopefully things are slowing down now. We have got the roof pretty well framed. The metal should be going on next time we can work on it.
PoleBarn Roof by nrc17gto, on Flickr
   / Pole Barn Build, 40x50x12 #63
Good lookin pole barn you got there.....Im finally getting around to digging my post holes and pourning my concrete footer. Its been kinda crazy around here for me too.....
   / Pole Barn Build, 40x50x12 #64
Hi Matt,
I would not say I am an expert by any means, but I can tell you what we did. We used a line level. To compensate for sag from the weight of the line, we stretched it between a few poles then put a nail partially in and stretched it again.
Someone else here may have a much better method. Good luck with your build!
Nick
I'm not an expert, but have used a few surveying tools and built some buildings. My Grandad taught me to level with a couple of garden hoses hooked together and filled w/ water, if it's not freezing. Water seeks it's own level. I've since moved on to a spool of clear aquarium air tubing and a jug with colored (food coloring) water in it. It's about $5 for 25', you can fit as many pieces as you need together for a pittance, works in bright daylight, doesn't need batteries.
For your barn you would need 3 or 4 pieces.
I suppose you could use antifreeze if it got cold.
   / Pole Barn Build, 40x50x12 #65
It works well as long as there are no bubles traped in the tube.
   / Pole Barn Build, 40x50x12 #66
Never had a problem with a garden hose, but with the narrow tube all I do to set it up is start suction on 1 end and let it fill,
I agree if you mess up and let air bubbles in, cut the tube, or hold part in the middle way to high it won't work.
   / Pole Barn Build, 40x50x12 #68
I laid out batter boards for my 30x45 building last weekend, and I have a 5 gallon pail full of water with a hose barb near the bottom, and 50' of clear tubing. After I was done, I checked them all with a 6' level, and they were all dead on. Just set it on a table when filling until water is running out the end of the hose to make sure all the bubbles are out.
Well, we completed the roof yesterday. Feels like a major step toward completion.
PoleBarnRoof by nrc17gto, on Flickr
Nick
   / Pole Barn Build, 40x50x12 #70
im new here, dont mean to be pushy by any means, but can we get an update please?
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2007 GMC W4500 Landscape Dump Truck (A55788)
2007 GMC W4500...
2008 New Holland B110 MFWD Loader Backhoe (A55302)
2008 New Holland...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
