Can a BX move round bales?
/ Can a BX move round bales? #1
Haywire
Central Kentucky
Tractorless :(
Title pretty much covers it. Will a BX2660 with a 3PH bale spear lift and move a round bale? I have no idea what they weigh.
thanks,
Ian
/ Can a BX move round bales? #3
thanks,
Ian
I'll just go ahead and say no...you need to move into the L series to deal with round bales, even the small ones.
/ Can a BX move round bales? #4
I am guessing here, but I would say no. My reasoning:
Often the bale is way back there, so that will challenge the lift.
Also, unless on concrete, the BX will not clear the muck that results from cattle feeding.
I figured as much, but I thought I'd ask.
thanks,
Ian
Edit... went to that link. Didn't realize that round bales could weigh a ton. Had I known that, I wouldn't have asked the question.... LOL
/ Can a BX move round bales? #7
As has been mentioned, round bales can weigh from 600# to 2000#. You also need a fair amount of vertical lift since they sit compressed on the bottom and a foot of lift may still have them dragging.
Ken
/ Can a BX move round bales? #8
The other thread has my BX lifting a 4x4 round bale with the FEL. normally this is on the 3pt with a hay spike and I have 0 issues. I keep the FEL on for counter weight of the 3pt, and go slow and keep it on relatively smooth ground and it doesn't feel tippy at all. So in a word YES it can do it and you do not need to get an L series, but I would think of how often and how far you are going with a round bale on the tractor. I generally only need to about 400 or so feet from storage into the horse paddock and I am only doing this once every 2 weeks.
/ Can a BX move round bales? #9
I have flat ground, and my kids use an RTV to help "move" them around the field.
/ Can a BX move round bales? #10
That's the smallest bale I've ever saw. Bales around here would hold several of those!!! :laughing:
For this OP he needs to clarify the size of bales he's using. The bales used here couldn't be carried with a B and an L would be looking for a little ballast on the front. :)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Bandit 200XP Wood Chipper (A63689)
Bandit 200XP Wood...
SKID STEER PLATE GRABBER (A62613)
SKID STEER PLATE...
2019 Ford F-550 Truck, VIN # 1FDUF5GT5KDA27067 (A65563)
2019 Ford F-550...
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
