need help.. Dogs and electric fences..
/ need help.. Dogs and electric fences.. #11
Putting electric fence around the bottom of the chain link would work but it would be a real pain to trim around and keep weeds out. If you are thinking electric then invisible fence would be the best choice. When I put my horse fence up I also wanted it dog proof. No-Climb horse fence stretched tightly deters my digging dogs on 99% of my 10 acre pasture. But there are small dips and valleys in the land that allowed some gaps for my dogs to dig under. I cut small sections of pig panel about 12" high with the bottom 4" cut so just the vertical legs of the fence gets hammered in to the ground. Pig panel is good for stopping hogs rooting their way under a fence and works very well for dogs digging their way under a fence also.
just get a clipper fencer, or use a chemical to treat the fence line.
soundguy
/ need help.. Dogs and electric fences.. #12
Electrified fences for dogs is really not necessary. Even a buried wire that trips a shock collar is a poor substitude for good training. I finally resorted to a shock collar that I can activate with a transmitter from 1/2 mile away. My dog quickly learned her limits after frequent walks around my property lines. I have not had to use the shock collar in months.
/ need help.. Dogs and electric fences.. #13
We keep shock collars on our dogs anytime they are outside of a fence. And this is every day for a short time each day. Shock collars work extremely well and are an excellent training tool if used wisely. To sit and watch for a dog in the back yard all day and wait for the opportunity to shock it when it starts digging is simply something neither my wife or myself have time to do.
/ need help.. Dogs and electric fences.. #14
....Chances are they won't even need the collars once they have been introduced to the 'shock' initially...
Had a Samoyed named Titan that was always getting out. First he was going under the chain link fence. So I made some U's out of rebar and tacked the bottom of the fence to the ground. So then he started going over the fence. This was dealt with by chaining him to a ground anchor. He broke the first 3 standard wire type dog chains. Went and got a welded link chain. He dug the anchor up. After coming home from work and finding him outside the fence with chain tangled in it I was afraid he would hang himself. So we got an invisible fence setup. On this particular model the collar would emit a tone to warn the dog before the shock. It worked well for the first couple of weeks. Then Titan got out again. The battery in the collar was dead. Now this battery was a high output photo flash type. About $6.00 each. So I put a new battery in the collar. This kept him in the yard about 1 week, then out again! Checked the battery and it was dead. Another 6 bucks for another new battery. This one lasted less than a week. It thought the collar was defective, but then I noticed Titan sitting near the fence one day. I watched carefully and he would patrol the fence staying about 3 feet away. He had figured out that when the collar stopped making noise, because the battery was dead, it was OK to jump the fence!!!
/ need help.. Dogs and electric fences.. #16
i've been shocked by a fencer dozens of times. heck.. before I had a fence checker tha's what we did was band the back of our hands against the wires.
I live in ag areas.. been around animals all my life.
I've never.. ever.. ever once heard of a large animal being killed by a fencer.
I've seen plenty lightning struck animals, I've seen plenty of animals run thru fences, and I've seen horses and cattle hung in fences so bad they had to be euthanized.
i would be inclined to believe the concept of a large animal killed by a fencer to be a myth, or if it has happened.. it is/ was on such a limited basis / scope as to be statistically negligible when compaired to the amount of animals contained with an electric fence. ( population size vs incedent ).
I've have to see repeated, verifiable hard data to think otherwise.
I'd also be inclined to believe that an animal could become entrapped in a wire fence and wear itself out struggling to free itself and then die from the struggle or the entrapment, and the fact that it was electrified was simply an aggraviting factor. IE.. cow trappe din field fence hoplessly, and unable to get to water for a week in a remote area, and died eventualy.. and oh yeah.. it was an electric fence.. so that must have killed it.. not the 7 days of struggling in the heat down on the ground with no water.. :( IE.. skewed data..
soudnguy
/ need help.. Dogs and electric fences.. #17
There simply isn't enough current in an electric fence to kill any animal. It'll hurt them, possibly even burn them, but it can't kill.
/ need help.. Dogs and electric fences.. #19
I have a Pet Safe wireless fence for my Border Collie and it has did pretty good at keeping him in. The collar has a red blinking light that comes on when you need to change the battery. If I neglect to change the battery he will wander out of his perimeter. Some times the area for his boundery will increase or decrease I guess it is because of the atmospheric conditions affecting the radio signal. By the way the audible sound that warns him he is close to the perimeter stops him before the shocking starts.nearly all the time after he learned his boundry.
/ need help.. Dogs and electric fences.. #20
Impressive. :confused3: It isnt a game. Use one that gives no warning, shocking based on only a proximity cue, and escalates with frequency. A battery warning light would be good too.
Display Pedestal (A59317)
Display Pedestal...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
