Why Build an ICF House
   / Why Build an ICF House #11
HGTV had a show called Dream House where a guy built his house from concrete. Before they started, he researched all the ways to build and what would be the most energy efficient, strongets and cost effective. He went with concrete. What made the show so interesting was all the problems they had in building it, and then turning that frame into a house. It was basically one disaster after another, every little thing that had to be changed, or added because a huge deal.
Just like Log Homes, they tell you that the mass creates a thermal barrier and it holds it's own energy. It sounds great in theory, but in reality, it's just not there. The foam on inside and ouside of the concrete is where you get your insulation. Once you have it built, will you have to stick frame the interior walls anyway? Will you remove the foam and use the concrete as the interior wall?
Have you read through Sam Walton's thread on his concrete house? It's an amazing project, but his cost for square foot isn't even close to what you could do it for stick built.
Just my opinion, but I think that it's going to cost twice as much to build a house with ICF's to the finished, livable, all done home that you will live in then it would using standard lumber and building to code.
The new Florida Code for Hurricanes is very impressive. From what I've read, they have really improved it. Same with CA and LA. Not all homes are built the same, and in some parts of the country, there is some real engineering that goes into these new construction houses!!!!
I'm not against building with concrete, and think it's a great method for a variety of reasons. What I'm against is the added cost that I feel makes it cost prohibitive for anybody with a budget. I also don't have any experince with it. I work with wood, and have a good idea what that costs. Before doing anything, I would talk to at least ten people with ICF homes who built them theirselves or with contractors, but are the original owners to find out what they say about the cost of building it was. Not just the frame, but to completely finish it and to be able to live in it.
Eddie
Eddie
No, you don't have to build a stick wall inside of the house, the drywall is screwed to the ICF blocks at certain places.
You don't remove the foam as that is your insulation - The electric is placed in the foam by using a router to make a groove - It's easier to router foam then it is to drill holes in wood.
   / Why Build an ICF House #13
Thanks. I remember reading that now that you've reminded me of how it's done.
Eddie
   / Why Build an ICF House #14
Our basement is ICF. When I was doing the wiring in the walls I used an electric hot knife with a loop tip. It cut/melted a pathway very quickly then I used the pieces that came out to fill in on top of the wires.
   / Why Build an ICF House #15
I don't get it, if it's even 10% higher that would not be enough to turn away people who are building their dream home ...
The monthly payment on a $250K home with 20% down & a 5% APR, 30 years = $1,073.64
10% more for ICF: The monthly payment on a $275K home with 20% down & a 5% APR 30 years = $1,207.85 ... $134.21/ month more. A total of $48,313.95 more over the life of the loan.
Seems most people buy the most home they can afford ... so will they be willing to reduce the size, features, etc. in the home in order to opt for ICF?
   / Why Build an ICF House #16
This is a fact! Dad & I built a sunroom addition to my sister's house in '08, & even being a big room full of big windows, I'd take my chances in there during a hurricane over any place in my entire 1992 home.
   / Why Build an ICF House #17
Bing Bing. :D You can buy ALOT of very expensive energy for $134 per month. $134 is more than my average monthly power bill.
We wanted to put in active solar water and house heating in the house. Best estimate was about $9K on top of the HVAC. No way could I justify the extra cost of something to supplement the HVAC heating and wood stove. The wood stove is more than enough until we have those few days a year were the temps drop into the single digits or teens. We could buy a second wood stove for much less.
Later,
Dan
   / Why Build an ICF House #18
I'm considering ICF, at least for the basement. If I do it myself, the cost is about the same as hiring someone to pour a basement. DIY, you can build ICF for about $6 square foot, depending upon local concrete costs. You can buy SIP's for $4/$6 a square foot, although they obviously wouldn't work for a basement. I can stick frame, with external foam insulation and blown-in cellulose for a little under $3. All of these numbers are square feet of wall area, not floor plan space. From the least expensive to the most is $3 square foot, or about $6000 in the case of my small house. Really not much money in the grand scheme of things. Bear in mind- that's DIY. I had a builder quote our modest 1300 sq ft design, and they wanted $95,000 for just the shell. That includes roofing, windows, siding, and doors.
What do I like about ICF? Strength, airtightness, quiet, doesn't burn, rot, or get eaten by termites. I think it's a good system to DIY, provided you have some skills, and can get an experienced person on site before you pour. One person can stack and brace the walls pretty quickly, working alone. SIP's would go up pretty fast, too, but would be harder to do solo.
What do I NOT like about ICF? Expensive (if hired out), termites are known to tunnel undetected through the foam, and it's very difficult to make changes to the house down the road. Want to add a window? We're talking heavily reinforced concrete- ouch!
I'm building in SC, which is rated 'Extreme' for termites. If I can convince myself that termites can in fact be controlled, I'll go ICF on the basement. My contractor only builds ICF, and he will run the pour (for a fee) if I want to stack my own blocks. If money were no object, I'd go ICF to the eaves, with metal SIP's and framing for the roof.
   / Why Build an ICF House #19
I had a 3500 sq ft ICF house built in 1994, and I still live there. I got a quote for 2x6 construction and it was about $2000 less than ICF. Concrete cost depend a lot on local availability of raw materials. You don't want to transport sand and gravel long distances. Let me summarize below
1. Average heating and cooling cost per month for the first 5 years was $30.
2. We could hardly hear hurricane Isabel when it passed through. We don't hear thunderstorms, ie they don't wake us up.
3. I did the wiring and it was not difficult to cut channels with a hot iron (electric charcoal lighter).
4. Don't get the first house built by a builder. Mine was the third. There is a learning curve.
5. The local power company did a blower door test and we were twice as tight as the next best house ever tested by the test person. His house was the second best and he did everything he thought possible to seal it.
6. Be sure to put in an air to air heat exchanger. Odors can build up.
7. Humidity is the biggest cooling load. Do not oversize your AC.
   / Why Build an ICF House #20
If you live in a region where autoclaved aerated concrete is produced/distributed, you have a much more elegant solution than ICF.
Autoclaved aerated concrete has both mass and insulation built in through the fine pores throughout its structure. The blocks can be cut with the same equipment used for wood working, taking account that lots of dust is generated with power equipment. One builds walls much thicker than with regular concrete. Below grade I would not use AAC, there is no need since with just 2" of extruded insulation on the outside, there is minimal heat loss through regular concrete.
Inside the shell, one can do interior walls in AAC block too, just thinner. In areas like bathrooms, a cavity wall can be built to conceal all the plumbing. There are core drills to drill holes through the block and it is much faster than on regular concrete.
The acoustics of a home built with AAC or rammed earth are in no way comparable to any stick built home. I have not yet experienced a SIP home, but it will be damped too, but light rigid panels also make good membranes to transmit low frequencies.
I was in Weil Am Rhein in Germany when hurricane Lothar swept in on the 26th of December 1999. Winds peaked at over 200mph. Thousands of square miles of forest was blown down in seconds. A "few" buildings had their roofs blown off, generally in 1 piece. Many older buildings lost tiles from their roofs. The 3 storey home I was in lost about 15 tiles from the roof. Not a single window broke and the air was not filled with debris, like what one sees here in the US in tornados.
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
KMC 3360 4-row Basket Dump Peanut Combine (A52128)
KMC 3360 4-row...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
