Kioti CK20 vs New Holland TC29
/ Kioti CK20 vs New Holland TC29 #1
sjohnson79
Member
Oxford, OH
2008 John Deere 2520
Hello!
Have a question as I'm new to buying a tractor.
I recently perchased 5 acres to build a home on. Land is very flat with 12-14 trees (will have more at some point), I plan on having a garden and building a large deck, and a fence around the back half of the property (auger use at some point). And of course a lot of grass to mow.
So...
Here are my options:
Kioti CK20 with loader KL120, 21-22hp, 4X4, hydro, 60" belly mower mm20-60, and a rear PTO tiller for $8500 (not sure if the tiller is in the deal or not but the seller has committed to the load and deck for $8500 but I will offer $8500 with the tiller) CK20 has 420 hours and is 5 years old.
NH TC 29, 4x4, 29hp, hydro ..on eBay.. ending soon! 550 hours, 72" belly mower, loader, priced at $9600 right now but I think it will go for 10,000+
New Holland 7308 TC29 Tractor w front loader & 72"mower - eBay (item 120731428414 end time Jun-09-11 13:19:46 PDT)
Thoughts, opinions, suggestions?
Thank you in advance!
/ Kioti CK20 vs New Holland TC29 #2
5 acres points to the Hew Holland.
Best of luck with your purchase.
/ Kioti CK20 vs New Holland TC29 #3
Neither.
for 5 acres of lawn, you should be looking at a zero turn mower with at least a 72" deck. My neighbour just bought a used commercial unit, and it is amazing how fast he can cut grass. It kills my 50" lawn tractor.
Neither.
Very true but just not in the market for a zero turn, I need the tractor outside of mowing.
/ Kioti CK20 vs New Holland TC29 #5
Neither.
Sure, if that was his only task.
He is going to be building a house and maintaining that 5 acres.
The man deserves and the tasks require a tractor.:thumbsup:
/ Kioti CK20 vs New Holland TC29 #6
I'm partial to NH. That said you need to look at dealer availability in your area. At some point all machines require parts and service.
/ Kioti CK20 vs New Holland TC29 #7
I have a TC29 and it handles a 6 ft. finish mower with no problems. Never operated Kioti, but several people swear by them. Have had zero problems with TC29 in 3 years. Most of my mowing is done with zero turn.
/ Kioti CK20 vs New Holland TC29 #8
The NH is 25% heavier than the Kioti (2500 vs under 2000 lbs) and 29hp compared to 20hp. Depends what you feel you need (or would like)
Loren
/ Kioti CK20 vs New Holland TC29 #9
I have a TC29D with loaded R4 tires, the tractor is great but it will make ruts in your lawn.
/ Kioti CK20 vs New Holland TC29 #10
Personally, I feel the 29HP NH is too much tractor for your needs and will only be a larger heavier tractor using more fuel doing the same task a much smaller tractor can accomplish. A 20 +/- HP tractor would fit your needs perfect so I would start with tractors in the same class as the CK20 like a Kubota B-series, JD 2300 series, TYM 273, etc...
Of course I'm a little biased towards the Kioti since mine has been outstanding so far at 6 years and 460 hours but I've never mowed with it either.
2019 Toro Dingo TX525 Mini Skid Steer (A60462)
2019 Toro Dingo...
207274 (A52708)
207274 (A52708)
John Deere 6 Row Do All (A60462)
John Deere 6 Row...
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
RoadTec RP190 (A61307)
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
