JD 790 First Impressions & Questions!!!!
/ JD 790 First Impressions & Questions!!!! #1
MaxxB
Member
NEK Vermont
JD 790
Well, got the little bugger home last night. Its a 30hp version with a 70 series bucket. EDIT: I forgot to add: 300 hours!
Most of my tractor time has been on a JD 5000 series and sketchy ol farmalls (no offence IH, just trust me when I say sketchy). Coming from the larger JD, I was doubting myself and the tractor going to a CUT level machine. Reading a bunch on this site particularly gave me confidence moving forward. That and our 15 acres is better paired with a smaller machine.
Anyway, I was got some time on it and I have to say it really exceeded my expectations. Plenty of power and despite only 2 ranges you can really creep (I love low gears) and much to my surprise I was able to go down the road at a good clip (which is great because I have field work down the road). The tires are supposedly filled, but I still need some more rear weight.
The one thing i failed to pick-up on when test driving it was a grinding/racheting sound from the right brake. (when you push both pedals its not as noticeable). I am gravely concerned by this. I did see in another thread here that it could be as simple as glazing on the shoes. I'm really hoping that is all that it is, which I find hard to believe because it sounds more like a gear sound to my untrained ears. :( I'd really truly appreciate any insight on this! If the vote is its only brakes...then i can rest easy.
When it comes to wheel weights, are they gonna be JD specific or are there generics too? Are they more or less universal in size or specific to models as well?
Last ( for now!), where can I get a grill guard...mine didn't come with one.
/ JD 790 First Impressions & Questions!!!! #2
Wheel weights r very exspensive! I would get or make a ballast bx or buy a implement for the back(tiller/bx blade) something like that. Brakes should not be gone with only 300 hrs. Mine has 950 and brakes still good. Need 2 get a shop man. 4 it, so u can do the work on it yourself. U can get on the jd website and look @ how to get to the brakes. Not hard! I would change all filters and fluids so u know where u stand with that.
Thanks! Are you suggesting that its not the brakes :confused: The other thread I linked to the guy said his had low hours too and others suggested possibly just brake glazing....
I cant stress enough...if its just brakes...i can rest easy. if its something else......
/ JD 790 First Impressions & Questions!!!! #4
Might try eBay for a grill guard. Lots of fabricators making and selling on there. It's where I got one a few years back.
/ JD 790 First Impressions & Questions!!!! #5
Pull that plate that is covering the shoes and check. Nothing to it! No not saying not the brakes. Probably glazing as said. 1things 4 sure, if it's not the brakes "IT'S GOING TO BE EXSPENSIVE" I bet, being a John deere! Good luck!
Will do....but I want to be clear. In the thread I linked the gent there described the sound as grinding/ratcheting...his symptoms are identical to mine.
Would there be any chance of differential failure which would only make a sound when one brake was applied? :confused::(
/ JD 790 First Impressions & Questions!!!! #7
I doubt u have a gear issue! It would more than likely do it all the time, not just when u put on brakes. Unless it's the spider gears in the rearend. That's why I said change all your fluids. The screen under the bottom of the tractor 4 the hydrolic system can tell u alot( metal shavings, chunks of metal,etc). It holds alittle over 4 gallons of fluid. Change front gear oil also. Nothing like knowing when the fluids/filters were changed and the right stuff put it in it. U probably got yourself a good tractor that will suprise u with ? it can do. Keep us up on it.
/ JD 790 First Impressions & Questions!!!! #8
...The tires are supposedly filled, but I still need some more rear weight...
For what it's worth... I have a 955 which a similar sized tractor with the 70A FEL (virtually the same as your 70 FEL). For the 955, the 70A loader manual recommends liquid filled rear tires, 3 wheel weights per side (the weights are about 60lbs. each) AND about 700lbs. on the 3pt for ballast. Seem like a bit of overkill to me... but that what the manual recommends. So, yes, you're going to want to add some more rear weight.
I believe the 790 and the 955 use the same rear wheel weights... last time I checked, they were about $130/ea. That's $780 plus tax just for wheel weights. Over $2/lb. for weight seem pretty expensive to me. I've seen some used weights for sale in the past that were selling for $2.50/lb. They are kind of an odd shape and not very "universal".
/ JD 790 First Impressions & Questions!!!! #9
That's why I said I would just buy me some kind of implement and fill my rear tires with fluid. Weights r crazy $$$$$$$$$$$$$$$$$$!
/ JD 790 First Impressions & Questions!!!! #10
To the best of my knowledge, a J.D. 790 and 3005 are the same tractor. So when you look for weights and things this should broaden you scope. Please correct me if I'm wrong. I can take it.:D
/ JD 790 First Impressions & Questions!!!! #11
I had the same model 790 and 70 loader combination as you do. (older 30 HP engine too).
I loaded the rear tires and always carried an implement on the back for loader work......and this combo worked like a champion. I had shimmed the hydraulics too.....and cannot remember a rear wheel ever coming off the ground.
Keep in mind the tractor hydraulics do not have the heaviest capacities. None the less....this unit is nicely balanced and will pick up most everything you want to do with it.
You have a front weight attachement on your tractor. That is an optional bracket. When I bought my tractor I did not have a grill gaurd either.....nor the aforementioned bracket. I bought the bracket and made a grill gaurd to attache to this bracket. Worked out nicely.
Here is a pic.....and I'll see if I can find the thread if you cannot find it here via a search on TBN. (try "grille gaurd" in the custom area?)
Note the second pic.....as a result of that incident I put stair grating into the grille guard to eliminate future occurrences. Operating in timber is rough on things. I see your hydraulic lines have had an incident or two also. Beware.....branches will get 'em. Don't ask me how I know. ;)
OH....keep in mind that the gaurd needs to be carefully placed in order to get your hood open and needs to tilt to get access to your battery (if made similar to mine).
Wow, thanks for all the info everyone!
Seems like getting an implement will be the excuse i need to take care of my ballast issue. nice!
I'm on the prowl for wheel weights though...i didn't realize they were gonna be so expensive! But, I've got a good feeling about a few neighbors of mine.
regarding the grille i think I'll see if i cant barter my way to having a friend weld me up something fun. I think what I might do is get a gel battery and install remote posts. Even if i don't need to access the battery, it should make for easy jumping on other vehicles.
I'm going to really lay down on that one side that's got the brake chatter and get back to you all. I do have another neighbor with a shop who tinkers on this and that so i might have him look at the brakes too....not that I'm not somewhat mechanically inclined...its just that a gravel yard makes for crummy wrenching.
/ JD 790 First Impressions & Questions!!!! #13
Before you tear into the brakes, try this:
Run your 790 a half mile (or so) with your foot on the brakes (make sure the left and right pedals are hooked together). The chatter is probably a glaze and running as I suggest above might break the glaze. There should be enough pressure on the brake pedals to slow, but not stop the tractor.
My old 790 brakes would chatter too, and that's what worked for me. I'm pretty sure it's repeated, light pressure on the brakes that causes the glazing (which results in the chatter you hear).
BTW, you used to get that same chatter with some (automotive) disk brakes pads. That's when I learned the trick I described (years ago). I guess pad compounds are different now as I haven't heard of pads glazing up in years.
/ JD 790 First Impressions & Questions!!!! #14
My 2004 790 has the "two-pipe" grille guard, I wanted something a little more 'protective', so I made this from some 1/2" angle iron & a piece of expanded metal. ~~ grnspot
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2005 CASE 580 SUPER M SERIES 2 BACKHOE (A62129)
2005 CASE 580...
