Sthil FS75 burning arm
/ Sthil FS75 burning arm #1
etcallhome
WV,Preston County
JD 1026R
After checking weedeater for bad gas cap ...I sent Stihl an email about a FS75 I use every week or so for 2-6 hrs at a time.
While using this weedeater mostly on hill sides , my arm about 4 inches from elbow ,touches the engine cover just in front of muffler..It gets hot enough that I usually end up with a burn either the size of a m&m up to the size of a dime..
Just wondering if anyone else has had this problem..
MY FS110 with handlebar , I don't seem to have this type problem , and yes it is also being used on hillsides.
/ Sthil FS75 burning arm #2
I can only say that I have an FS110 w/ handlebars and never had an issue like you describe w/ the FS75 but I could see where the H-bar's would keep your arms in a different position further away from the engine ( assuming the FS75 has a "normal" handle set up). BTW....do you like the handlebars? I have to say that I think I now wish I had purchased without them. A "normal" handle just seems to be more natural and allow for easier extension/movement of the weedeater.
I got my letter from Stihl a couple of days ago, haven't checked my gas cap yet..........
/ Sthil FS75 burning arm #3
I have used Stihl FS80's for 6-8 hours at a time. They have caused my arm to bleed from wear and heat.
I like my handle bars for the 110 my old Shindawa had handle bar and when I bought the 110 I didn't think about buying one without the handlebar setup..The 75 has reg setup plus the 75 has curved shaft and at times with curved shaft on a hillside you just have to hold it at a complete different angle compared to a straight shaft, which the 110 has .
So yes with handlebars you do have your arms at a complete different area compared to a unit with regular setup.
/ Sthil FS75 burning arm #5
I have used the handle bars also with the FS80's. I prefer the loop grip. Pain from forearm burn and wear less pain than the shoulder and back pain the handle bars gave me. Falling down a steep hill while holding on to handle bars is a lot less graceful than when holding on a loop grip and falling down a hill. FS80's have the loop handle/handle bar option. There is a reason why they make loop handles. And there is a reason why the make handlebars.
/ Sthil FS75 burning arm #8
http://microsoftoutlook2010.momaroo.com/749263168/microsoft-outlook-2010-professional/
/ Sthil FS75 burning arm #9
My FS55RC gets hotter on my arm than I would prefer but has never actually caused a visible burn.
Mayrath 10 x 30' Truck Auger (A66285)
Mayrath 10 x 30'...
90in. Work Bench (A65640)
90in. Work Bench...
2013 Kobelco SK26LC (A64126)
2013 Kobelco...
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2020 WESTERN STAR  4900 TRI AXLE (A65643)
2020 WESTERN STAR...
