Toolbox
/ Toolbox #1
Crike
Member
West TN.
Bobcat CT450 Hydro
I've wanted to replace the small toolbox ever since I bought this tractor.This Stanley Fatmax was the only one that I could find around here that has a watertight seal and more than enough room for what I need. The only drawback is it blocks some of my view of the 3pt hitch.
/ Toolbox #2
Interesting, as I was looking to do the same thing, and after a dozen internet searches it seems the FatMax is about the only tool box reasonably available that meets the "watertight" criteria. Glad to see that it more or less fits the space, though it would be nice if there were something just a bit smaller...
/ Toolbox #3
I'm waiting anxiously for my CT235. My only dislike with the tractor is that the toolbox is pathetic. I am looking for a replacement even before I get the thing! This looks good.
So answer a question for a noob: What do I need in my toolbox on the tractor? What's in yours?
/ Toolbox #4
Hey Steel. You might keep in mind your plans for a BH, the BH will not allow for a large toolbox like that I don't think. My seat on my Woods hits the little worthless standard box. Just thought I would mention that!
/ Toolbox #6
I did about the same thing with an old craftsman steel tool box. I took the manual holder off the back of the seat so I could slide the tool box farther forward. It's got chains, straps, two big crescent wrenches and lots of assorted lynch pins. I hung the manual holder to the inside wall of my shed.
/ Toolbox #7
Actually I have an 8TB backhoe on a ct335, and on mine at least it appears that this would fit without issue, except for being a little larger than necessary (if there is such a thing). I suspect I'm going to give it a go as soon as I can find one, so I'll let you know.
... I took the manual holder off the back of the seat so I could slide the tool box farther forward. It's got chains, straps, two big crescent wrenches and lots of assorted lynch pins. I hung the manual holder to the inside wall of my shed.
Taking the manual box off would make it fit better, good hint. :thumbsup:
As far as what to put in it, even my stock small one is pretty similar to Pooba's: a couple of crescent wrenches, wire snips, some wire ties, a couple of screw pin shackles, and the mandatory lynch pins. One of the fellas in another thread had used some 4" pvc pipe mounted down in front of the brake (sst) or hst pedals to hold chains, and I kinda like that idea at the moment for those, unless I can come up with something better.
/ Toolbox #9
I am fairly new to all this stuff as well, but here is what I carry in the toolbox:
- Chains
- flashlight
- needlenose plyers
- Socket wrenches
- screwdrivers
- weed eater string
- wire cutter
- hammer
MoKelly
/ Toolbox #10
I found a picture I took last summer.
/ Toolbox #11
One of the fellas in another thread had used some 4" pvc pipe mounted down in front of the brake (sst) or hst pedals to hold chains said:
Can you point us to that thread? I'd like to see pictures of the PVC pipe. Great idea!
/ Toolbox #12
Here is what my chain holder looks like.
/ Toolbox #13
That's really a good idea. Thanks for the pic. I suppose a 6" pvc end cap (might need something larger though??) on a strap would make a nice lid for that to keep water out. I'm going to build one of those as soon as I get the tractor.
/ Toolbox #14
I used 4". I didn't put a cap on top but i put one on the bottom and drilled a few drain holes in it just in case. Tractor stays in garage if not being used, so shouldn't be an issue.
/ Toolbox #15
Here's a photo of my chain holders and chainsaw holder. I can't take credit for the concepts. I got the ideas from earlier TBN posts.
/ Toolbox #16
Thanks kco; yes, that is the picture I had seen earlier. I had considered something like rabidracin's design, but the thought of lifting and dragging the chains out over all the sheet metal was disconcerting, not to mention that these old shoulders aren't very happy anymore when lifting things at an arms length.
I used to work with an old Massey, and just kept the chains on the floorboard by my feet. They were handy there, easy to get to and not much chance to damage sheet metal, but unrestrained. This keeps them in a similar location while making sure they stay there...
/ Toolbox #18
/ Toolbox #20
What did you use for the chain saw mount? I can't make it out from the photo.
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2006 Utility Spread Axle Trailer (A62679)
2006 Utility...
(1) UNUSED 8.3-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 8.3-24...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
Yale Forklift - NO RESERVE! (A63688)
Yale Forklift - NO...
1992 FORD EXPLORER XLT SUV (A64280)
1992 FORD EXPLORER...
