LA210 Loader on BX2200 Tractor
/ LA210 Loader on BX2200 Tractor #1
hibshman25
Looking to install an LA 210 loader onto a BX2200 Tractor. The loader came with no mounts and one dealer tells me I can't put a 210 loader on the BX2200. I've done some research and many say the LA 210 attaches the same as the LA 211.
What mounting brackets should i buy? 210 or 211?
/ LA210 Loader on BX2200 Tractor #3
Unless someone here has done it and can tell you exactly what you need to buy...you'll have to do more research...take measurements to see where 10 and 11 bkts differ...bkt to tractor and loader to bkts...
/ LA210 Loader on BX2200 Tractor #4
Your dealer may choose to be helpful and let you have a peek at the parts list for the two loaders, so you can compare part numbers. Many times a manufacturer uses standard parts on similar models. If the FEL brackets are the same part with both loaders, it'll should fit either one.
If the dealer won't help or you would just rather handle it yourself, you may be able to get the same information emailed to you from TractorSmart.com.
/ LA210 Loader on BX2200 Tractor #5
:):eek::)
/ LA210 Loader on BX2200 Tractor #6
From what I have learned from Kubota is that there does not seem to be a system for compatibility that is applied consistently, capacities yes. For instance: An LA240 and 243 loader take the same bucket. An LA402 and 403 loader don't, loader arm spacing is vastly different. A LA364 and LA504 loader are almost identical in dimensions but the book says the buckets are not interchangeable. I know I am not answering your question exactly but saying you really have to measure and do the math, at least that is what I have learned to do. I have measured a lot of BX's and have noticed that the center cylinder is off center consistently between the loader arms by 1/16". That computes out to a 1/8" difference in measurement from side to side. I'm just saying what I have found, check it out for your self and PM me if you find the same thing.
/ LA210 Loader on BX2200 Tractor #7
I thought the 210 loader's valve stayed with the loader while the 211 loader valve stays mounted to the loader bracket. Can't comment on the exacting mounting parts.
23105 (A56859)
23105 (A56859)
John Deere 4520 (A60462)
John Deere 4520...
2023 CATERPILLAR 330 EXCAVATOR (A60429)
2023 CATERPILLAR...
2012 GMC Acadia AWD SUV (A59231)
2012 GMC Acadia...
FORKLIFT (A56857)
FORKLIFT (A56857)
2005 INTERNATIONAL 4300 SBA 4X2 FLATBED DUMP TRUC (A60430)
2005 INTERNATIONAL...
