L2500DT won't roll over
/ L2500DT won't roll over #1
carlav1410
Mt Airy NC
Kubota L2500DT 4X4
Hello all,
I have a 2000 L2500DT that won't roll over?
I have good lights,glow plugs heat up all safety switches are by pasted.
I have good voltage at starter.
Wondering if it could be the key switch causing my trouble?
Thanks to all
/ L2500DT won't roll over #2
I was going to ask how big a hill you were trying to roll it over on. :laughing:
Is there any sound from the starter? Clicks or groans?
You are sure the seat or clutch safety switches are not causing the issue? If everything is by-passed and there is no sound at all from the starter, perhaps it has gone out?
/ L2500DT won't roll over #3
Hello all,
Thanks to all
If you can hot wire it successfully, then it's time for a new switch. Or you could do a quick continuity test to confirm your suspicion.
Thanks for all your replies I'm going to test out the starter today.
I'm also going to check the key switch out to see if there is any voltage when the key is in the start position?
Thanks Again Carl
Back again,
I tested the starter and key switch have 12 volts at key switch went turned to start.
If i jump starter from large to small terminal tractor rolls over.
I'm thinking problem might be in wiring harness ?
Anyone have ideas?
Thanks Carl
/ L2500DT won't roll over #6
Most likely a failed safety switch. Bypass one at a time until you have joy.
Mike
Thanks to all,
I found the trouble.:D It was the arm on the neutral safety switch not pushing the pin on switch far enough in to make connection.....:confused2::confused: only wasted 4 hrs on it.:mad:
Again Thanks to ALL for the awesome advice Carl
/ L2500DT won't roll over #9
After adjusting free clutch travel on my L225DT, I had the same problem. Had to glue a metal block on the clutch rod to complete circuit. Took me a while to figure that out.
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
SHAVER HD-8 HYD POST DRIVER (A64277)
SHAVER HD-8 HYD...
2019 Isuzu NPR 14' Box Truck (A62613)
2019 Isuzu NPR 14'...
Four (4) TAG Excavator Couplers (A65640)
Four (4) TAG...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
Hay Rake (A65640)
Hay Rake (A65640)
