another "I just installed bucket teeth thread"...
/ another "I just installed bucket teeth thread"... #1
NOTV8
CT235
And wished I did it earlier. With all the ground works I'm been doing lately this teeth in the bucket really is a no brainer... I went with the bolt on one's instead of the bar cuz it was cheaper ;). Put 8 teeth on a 68" bucket for under a hundred bucks. :thumbsup:
/ another "I just installed bucket teeth thread"... #2
What was part number of the tooth kit you used? Did you have to drill extra hole in bucket to for them or does your bucket have the 2 hole pattern for the teeth?
/ another "I just installed bucket teeth thread"... #3
was wondering the same thing, need to do that on my bucket also
/ another "I just installed bucket teeth thread"... #4
VERY NICE:thumbsup:
I too was too cheap for a tooth bar and did the same thing.
But I also have to ask what teeth you used.
The ones I got ONLY bolted onto the top side of the bucket. Where as some of the teeth (more expensive) sandwitched the cutting edge.
Here is a link to my thread. It has some close ups of the teeth I used. Are yours the Same?? And did you have any issues drilling/tapping the cutting edge?
http://www.tractorbynet.com/forums/attachments/199977-my-new-bucket-teeth.html
/ another "I just installed bucket teeth thread"... #6
Thats not too bad of a price if the bolts/nuts were included:thumbsup:
I think I gave ~$78 delivered for my 8 teeth but that was no hardware.
/ another "I just installed bucket teeth thread"... #7
I bought the individual teeth with mine also and they really help with digging but I removed them last year when I was spreading rock and never put them back on. I have a Woods BH-80X that I use to dig with now. One of these days I will probably put them back on.
I think with the teeth and hardware, mine was $90.
Part # PS1686B for $7.59 each from AGIndustrial.com. I have to drill the back holes. Only have the front holes available orginally from the bucket. Bought some 1/2" grade 8 bolts (10pcs. 1.5" and 6pcs. 1"). and lock nuts for around/less than $10 bucks. Did not take long to install with power tools... Hope this helps with everyone's questions...
There are other choices in the site too but for the price of it I think this can't be beat :thumbsup:.
VERY NICE:thumbsup:
LD1
I think that is the same one's... only I did not have problem drilling... (well I used a garden hose partially open next to the hole I am drilling ;)).
/ another "I just installed bucket teeth thread"... #10
LD1
I dont know how much of that you read, but I had NO problems at all drilling the cutting edge.
Only problems was drilling where the edge was welded. Must have gotten MUCH harder there:confused2:
/ another "I just installed bucket teeth thread"... #11
Did you check on Bobcat teeth? They ran me a little over $12 each including the bolts and nuts. $87 total for 7. The holes lined up perfectly with the predrilled holes in my 68" Bobcat bucket. I had to ream out one of the back holes a little by hand, but the other 13 bolts just slid in. No drilling.
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A61165)
2002 Ford F-550...
2018 Ford F-150 4x4 Pickup Truck (A61568)
2018 Ford F-150...
PAIR OF 10' RAMPS W/10' EXTENSIONS (A62131)
PAIR OF 10' RAMPS...
(1) UNUSED 16.9-30 TIRE W/RIM (NO CENTER) (A62130)
(1) UNUSED 16.9-30...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
