another "I just installed bucket teeth thread"...
/ another "I just installed bucket teeth thread"... #1
NOTV8
CT235
And wished I did it earlier. With all the ground works I'm been doing lately this teeth in the bucket really is a no brainer... I went with the bolt on one's instead of the bar cuz it was cheaper ;). Put 8 teeth on a 68" bucket for under a hundred bucks. :thumbsup:
/ another "I just installed bucket teeth thread"... #2
What was part number of the tooth kit you used? Did you have to drill extra hole in bucket to for them or does your bucket have the 2 hole pattern for the teeth?
/ another "I just installed bucket teeth thread"... #3
was wondering the same thing, need to do that on my bucket also
/ another "I just installed bucket teeth thread"... #4
VERY NICE:thumbsup:
I too was too cheap for a tooth bar and did the same thing.
But I also have to ask what teeth you used.
The ones I got ONLY bolted onto the top side of the bucket. Where as some of the teeth (more expensive) sandwitched the cutting edge.
Here is a link to my thread. It has some close ups of the teeth I used. Are yours the Same?? And did you have any issues drilling/tapping the cutting edge?
http://www.tractorbynet.com/forums/attachments/199977-my-new-bucket-teeth.html
/ another "I just installed bucket teeth thread"... #6
Thats not too bad of a price if the bolts/nuts were included:thumbsup:
I think I gave ~$78 delivered for my 8 teeth but that was no hardware.
/ another "I just installed bucket teeth thread"... #7
I bought the individual teeth with mine also and they really help with digging but I removed them last year when I was spreading rock and never put them back on. I have a Woods BH-80X that I use to dig with now. One of these days I will probably put them back on.
I think with the teeth and hardware, mine was $90.
Part # PS1686B for $7.59 each from AGIndustrial.com. I have to drill the back holes. Only have the front holes available orginally from the bucket. Bought some 1/2" grade 8 bolts (10pcs. 1.5" and 6pcs. 1"). and lock nuts for around/less than $10 bucks. Did not take long to install with power tools... Hope this helps with everyone's questions...
There are other choices in the site too but for the price of it I think this can't be beat :thumbsup:.
VERY NICE:thumbsup:
LD1
I think that is the same one's... only I did not have problem drilling... (well I used a garden hose partially open next to the hole I am drilling ;)).
/ another "I just installed bucket teeth thread"... #10
LD1
I dont know how much of that you read, but I had NO problems at all drilling the cutting edge.
Only problems was drilling where the edge was welded. Must have gotten MUCH harder there:confused2:
/ another "I just installed bucket teeth thread"... #11
Did you check on Bobcat teeth? They ran me a little over $12 each including the bolts and nuts. $87 total for 7. The holes lined up perfectly with the predrilled holes in my 68" Bobcat bucket. I had to ream out one of the back holes a little by hand, but the other 13 bolts just slid in. No drilling.
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
8ft. 3 Point Blade (A65640)
8ft. 3 Point Blade...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
New Holland Hayliner 273 Square Baler (A65640)
New Holland...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
