336D PTO
/ 336D PTO #1
SSRTOW
YM336D
How does it work? I bought a 336d to put my 330 motor in and just got the 330's motor out and its got a double clutch PTO, the 336d has only one clutch disk. Does that mean when I hit the clutch no PTO? I like the Live PTO the 330 had ??
Paul
/ 336D PTO #2
The YM336 did not have a live pto, but with the powershift you can put the tractor in gear with out clutching, so it can be operated like a tractor with independent pto.
/ 336D PTO
I stood staring and thought for a while and figured that out, I guess with the powershift it would be fine. I am worried about clutching but it looks like I may not have too, I have three acres of grass to mow so I may yet like the powershift. :cool:
So what about backing up? I have read alot of differing opinions regarding powershifting into reverse without the clutch? I already just about landed in the loader moving the thing into my shop and accidentaly shifting it into reverse, I have no desire to do that again :confused:
Thanks for the reply lens12 :thumbsup:
Paul
/ 336D PTO #4
I've used tractors with the powershift to mow lawn with. You need to stop motion in one direction before shifting to the other direction. The model I used I thought would have been better if reverse was a little slower. I'd still use the clutch when using the loader.
/ 336D PTO #5
If you are using gear range 3 and you are running at around 2200 rpm, the reverse is pretty fast. If you use the powershift, hold on, and be sure that nothing is very close behind you.
I've gotten to the point that I don't use the clutch very often. I mainly use it when I want to gear down or if I am using the loader (I have one of the one ones that has the powershift on the transmission case so it is a bit difficult to get my hand back and forth from the shifter to the spool valve lever).
/ 336D PTO
I am starting to like the idea, I think I will keep the 330 and find a motor for it. I was going to part it out but I am attached, wish me luck finding a block.
I have some questions about the front axle on the 336, should I start a new thread or just keep going here? Thanks all :)
/ 336D PTO #7
What are you going to do again its not clear part one out or fix one or two?
Otherwise there is plenty of help here on that tractor ask away. :thumbsup:
/ 336D PTO #8
I have a 336D with power shift andlike it quite well. However, when using a PTO driven implement ( snowblower) if you forget and clutch and then reengage the clutch with out reducing the RPM's it will cost you a shear pin just about every time.
Joe
/ 336D PTO
I have spent most of today playing...:D I mean working on the tractor and its not so bad, I have not ran anything off the PTO yet but I am getting used to the powershift and the loader.
It seams that the arm on the fuel injection pump actuates the opposite way to the old motor, as of right now I have no foot throttle until I figure out how to change out the arm/pump or flip it around and connect. :(
I will work on Pictures, though I forgot to take any before I tore the two tractors apart.
Anyone need any YM330 Parts?
Thanks for your Answers :thumbsup:
/ 336D PTO #10
I like the power shift on my 336d but be careful if you have it in gear and just move the power shift to a neutral position and then get off the tractor. If you bump it the tractor will then start moving. If I leave the tractor running and leave the tractor I make sure both the trans and the power shift are in neutal positions.
/ 336D PTO
Heres pic of done tractor, before cleaning it up. Its got a ways to go to decent condition but it runs great now and goes pretty good too, although I have one complaint. There is a huge jump between 3/3 and 4/1, When mowing 3rd gear 3rd range is to slow and 4th gear 1st range is too fast? I miss my 330 already, I liked mowing with it. Anyway :thumbsup:
/ 336D PTO #12
Nice looking tractor. I'm guessing you meant 1st gear 4th range is to fast. :confused:
/ 336D PTO
hmm... maybe I have it all wrong?? Is the powershifter the range? or the floor shifter the range? :confused:
/ 336D PTO #14
I'm most likely the one all messed up. I thought the 336d was a gear transmission.:ashamed:
/ 336D PTO
oh, ok I still wonder which is which now.
/ 336D PTO #17
ON MY 336D (1985 ABOUT) THE FLOOR SHIFT IS THE RANGE AND THE POWER SHIFT THE GEAR SELECTOR I MEAN THAT IS WHERE YOU FIND REVERSE.
Yes, that's right. On the YM336d the range is set on the floor and you do the shifting on the go with the powershift. On mine the highest range is only good for roading the tractor. There is quite a jump between 3rd range and 4th range.
Do you have the super low creeper gears with the lockout lever as part of the range selection on the floor? In Creeper range on the floor shift and with Low selected in the powershift that is just about the lowest geared tractor I've ever been on.
rScotty
/ 336D PTO
I dont think so, could you describe better where I might find that lever? I have not noticed anything but the 4x4 lever, I will take a look.
Edit: I just looked and I have only the 4x4 lever and the range selector
Paul
/ 336D PTO #19
Let me throw this question out there: Is it possible to add Powershift to a non-Powershift Yanmar?? Sounds like that's what happened here, but only by completely swapping out the engine. Is there an easier route?
/ 336D PTO
All I did was swap out a bad engine for a good one, no other changes whatsoever. My 336d is as it came from the factory with maybe a few minor differences in the motor (internal differences) although externally (minus the throttle arm) it looks and matched up exactly.
I dont think one could go from no powershift to powershift without a whole new transmission, only way to do it right would be to buy a parts machine and take everything you needed. Bellhousing back, 336d trans looks totally defferent to the gear shift 330 tractor I took the engine from. Even the flywheel/clutch is different (although the drive clutch from the 330 is the same for the 336d)
Paul
2025 HT360W Mini Stand-On Track Loader Skid Steer (A64553)
2025 HT360W Mini...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
DYNAPAC  CP271 PNEUMATIC ROLLER (A67714)
DYNAPAC CP271...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2024 CATERPILLAR 239D3 SKID STEER (A65056)
2024 CATERPILLAR...
