knuck, knuck on JD3720
/ knuck, knuck on JD3720 #1
Deere Dude
Elite Member
Beaver Dam Wisconsin then to Hohenwald, TN
John Deere 3720
Maybe one of you can shed a little light on my 3720. I get an audible knucking sound when idling, wheels turned to right or left, Idling so I can hear easier. Wheels straight, it seems fine.I tap the hydro pedal to go forward or reverse, and let off the pedal I hear a sound that comes from the frame section someplace. I don't ever remember hearing that before. :mad:
It is a 2010, 3720 with 125 hrs. I checkerd the lug nuts and they are tight. I dion't see any loose hardware. I took the loader off, the 3 point attachment off. I took the top link off. I tied the 3 pt. lift arms together with a bungy cord. I looked underneath and don't see any loose stuff. The only thing that wiggles is the drive shaft for the front end. Boy is that thing whimpy, by the way.
If anyone else has noticed that on yours and know of a fix, please let me know. It's under warranty yet and if I don't find an easy fix by tomorrow I'll have to take it to the dealer. Thanks in advance,
/ knuck, knuck on JD3720 #2
I had a noise up front on my 770 when turning. Thought it might be the power steering cylinder but, what I found it to be was the center pivot grease fitting on the front axle.
Don't know if the 3720 has this type of fitting but, it may be worth a look.
Also, try posting in the Deere Forum here at TBN.
/ knuck, knuck on JD3720 #3
Maybe one of you can shed a little light on my 3720. I get an audible knucking sound when idling, Thanks in advance,
Not quite sure on this. While 'knucking' is the 'k' silent?
/ knuck, knuck on JD3720 #4
does it happen when u turning the wheels are after wheels are turned because i had a popping should before on a 4wd massey in the frontend and it was the grease fitting in the pivot pin where the plantery drive connects to the main section that was in need of some grease after i greased it the noise went away
The wheels are turned most of the way in either direction, and then I tap the hydro enough to move the tractor a foot or two, it makes the knucking sound, and then the same thing happens in reverse also. I'll check around for grease fittings.
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2008 Ford Expedition SUV (A61574)
2008 Ford...
2016 Hyundai Sonata Sedan (A61574)
2016 Hyundai...
