english made ford 3000
/ english made ford 3000 #1
dcampbell
ford 3000, ford 5000
Help! Hole in fuel tank, cannot find a replacement with a long enough fill neck. All of the tanks I have been able to find are for american built 3000's. Even my local dealer is unable to help. Anyone?
/ english made ford 3000 #2
I feel your pain. I had one of those versions too! Parts are a pain to find for it. How bad is the hole? Is it rusted or punctured?
The hole is on the bottom of the tank, left of center and a little larger than the diameter of a pencil. I have also noticed that the metal is rather thin everywhere on the bottom of the tank. Some small pockets of rust, too.
/ english made ford 3000 #4
are u sure since the english built fords and the american built fords only had different wiring harness, lights and fenders everything else is the same
/ english made ford 3000 #5
and are u sure u dont have a 3400 because there fuel neck is about 1.25 in longer because all 3000 use the same tank
/ english made ford 3000 #6
Mine had a generator that was different and took for ever to find an old dipstick they were different lengths and on the opposite side of the American. But filters, fenders, axle parts and such were the same. Everytime something failed, it was a shot in the dark as to weather the part was the same or not.
/ english made ford 3000 #7
thats what i said the electrical system is different but all the ones i have ever owned had the dipstick on the same side
/ english made ford 3000 #8
Hmmm:confused2:? Just relaying my experiences.
/ english made ford 3000 #9
post a pic of the machine front and side
post the number on the trans bellhousings.. there will be 2-3 rows of stamped numbers.
something don't add up here.
the 3 cyl family of similar engines should have the dipstick all on the same side..
soundguy
/ english made ford 3000 #10
I don't have mine anymore. Sold it when we bought the GC.
/ english made ford 3000 #11
soundguy
thats what i thought since all the castings was the same
/ english made ford 3000 #12
message was intended for the OP.. so we can help ID his machine and see why parts are an issue.
the basildon parts shouldn't be that much different for the basic chassie..
soundguy
/ english made ford 3000 #13
that's what I'm thnking.
my 3000 and 4600 fall into this category.. and thats quite a year spread.. it.. 65-79 on that smae basic 3 cyl block.
soundguy
/ english made ford 3000 #14
The only thing that having the dipstick on the other side of the block tells me is the engine is a lot newer then the rest of the tractor. Doesn't matter where the final assembly was done, ALL '65 and up Ford engines were built in Basildon and were identical for a given timeframe.
Original generators were all Lucas regardles of origin. My B-prefix 4000 has the same generator & regulator as any C-prefix Thousand series.
/ english made ford 3000 #15
would the dipstick on the other side indicate somehting like a farmtrack / indian replacement engine?
or somehting from the 30 series perhaps?
soundguy
Here are the requested id numbers. Thanks everyone for the help! F295 A110-086
Upon further investigation, another set of numbers was located above the posted numbers. They are...5 F 14 C. Thanks.
/ english made ford 3000 #19
replied via email before I saw this.
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2005 Airman PDS185S Towable Air Compressor (A64194)
2005 Airman...
2026 SDLANCH SDLC1220 High-End Carport (A64194)
2026 SDLANCH...
