YM2000 running hot
/ YM2000 running hot #1
Brake Weight
Southern Miss
Yan Mar YM2000
First post.
I've had my YM2000 for several years now. I changed the water pump last year when it started to run hot, and drip at the shaft. It runs cooler than it did prior to the new pump, but it's hotter than it was originally. It holds around the 200F mark, or a needle width higher when running the finishing mower. Which isn't so bad compared to the others here that I've read.
When it starts to get up to the boiling mark(ususally involves it running a 4' tiller or 4' bush hog in high grass) I'll cruise over to the water hose. Put a few shots onto the radiator and letting it idle until it cools off.
Question is, does the YM2000 have a thermostat? When I let it idle cool, there's a noticable drop in temp and a change in the sound of the idle that corrospond. Is this a bad thermostat or just a coincidence? Also, is this a bad practice? As this is my first diesel.
/ YM2000 running hot #2
Don't believe the 2000's have a thermostat. I'm sure your exterior radiator fins are good and clean allowing good air flow? If so, your radiator might need a good flush job or tanks taken off and cleaned by a radiator shop. New radiators are high. Yanmar Tractor Parts: RADIATOR _
/ YM2000 running hot #3
What Winston said. My YM240 had a freshly rodded-out radiator when I bought it and it has never gotten hot. Well, at least after I learned that mowing includes the necessity to flush chaff out of the radiator fins occasionally.
And there isn't a thermostat. I used to put cardboard in front of 2/3 of the radiator for light work in cold weather but I don't bother any more. In theory keeping it hot will let it run more efficiently and avoid crudding up the rings and injectors, but in practice I don't know that it makes any difference.
/ YM2000 running hot #4
I flushed my radiator (YM1700) recently after buying it. There was a LOT of junk in there. When I re-filled, I used a 30-70 mix and added Water Wetter. I do not have a water pump on mine; it circulates by convection. It runs at around 200 under a good load.
/ YM2000 running hot #5
You need a clean cooling system and it should have antifreeze good to -40F to work efficiently. Cooling system must be clean internally and externally. Test it with an inferred tester, when it is hot you can test if the coolant going into the motor should be at least 20 degrees cooler than what comes into the top of the radiator.
Just a thought!
Thanks. I flushed it with my water hose when I changed the water pump out. I may pull the radiator anyway to have a look. The fluid at the top of it is nice and green, and rolls around when I look at it w/out the cap on after I first crank it.
Just a thought!
I actually have one of those. I'll do it next time I run it.
/ YM2000 running hot #8
If there is no junk like grass or seed built up on the radiator i would say that you need to have that radiator professionally cleaned. You may have some rows that are crudded up and not working.
And i second those others, there is not thermostat
I just ran it again. I made about 15-80' passes between my rows and it got hot. Gauge said it was near 220. Infared thermometer said it was 210 into radiator, and 195 out. I guess I'll be cleaning it out soon.
/ YM2000 running hot #10
You might first try using some of the stuff they sell at autoparts stores to flush radiators.
/ YM2000 running hot #11
A day-old member here so be gentle... Just last week I was looking into a 'flush' that could adequately clean out the passages in the radiator effectively. Thinking back, I remembered that vinegar, being a mild acid, may serve as a excellent means of removing buildup from within the plethora of channels in the radiator. I 'googled' radiator & vinegar and came up with quite a variety of hits. Some touted great results whereas others claimed to have leaking radiators after treating with vinegar. Frankly, I cannot see that vinegar could eat away at a brass radiator to the point it would leak unless it was already near the point of failure prior to treatment (leakage would be expected regardless of the cleaning medium used it if the condition was already that poor). Vinegar is the solution recommended to clean the internals of coffee pots. Scale on shower heads dissolves right before your very eyes when treated with vinegar... so why not radiators?
If am curious if anyone here has first-hand experience with the vinegar method? Granted, a commercially-available radiator cleaner should do the job in which it was designed for... but what about the home remedy of vinegar?
Caveat - I am too new here to have searched the topic of raditor cleaning and vinegar so I apologize if this has already been discussed within this forum. Further, I have no intentions of highjacking this conversation; instead, I was hoping to piggy-back on Brake Weight's dilemma to solve my question.
/ YM2000 running hot #12
Daryl -- Regarding the people who had a leak after cleaning; the people you mentioned interpreted this to mean that flushing caused the leak. In way they were right since it wasn't leaking before and was leaking after. What really happened is that the dirt (or whatever) inside the radiator was plugging the leak. When they cleaned it out, the leak was no longer plugged. Same thing happened to me.
/ YM2000 running hot #13
The best flush I have ever seen is Arm and Hammer washing Soda. What I do is drain the coolant. Then with a pail of hot water a little more than what you removed from the COLD engine, mix the soda with a paint mixer, let it sit for 1 minute, and pore into a different container, and then fill the system every last drop it will hold OVERFULL, when the coolant blows out it will clean the top of the rad or the surge tank.
If there is even a hint of oil residue in the system add a little Dawn dishwasher soap.
Start it and at idle, fill some more if possible, Work the unit, drain, refill, and keep doing it until it comes out with no colour and no scale. When draining it will not hurt anything except the heat. If you do it on a cement pad it is amazing the scale that is cleaned out.
I have used a lot of products working for engine and truck dealerships, none of them worked as well as this and it is cheap. If you want to spend a lot of money Cummins make a product called restore that works, not as good but more expensive.
HANDICAP PORTA POTTY (A68842)
HANDICAP PORTA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
TANK MANIFOLD (A67714)
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
2013 Ford F-150 Crew Cab Pickup Truck (A66736)
2013 Ford F-150...
