2520 ballast box
/ 2520 ballast box #1
Campjd
PA
2011 John Deere 2520
I'm wondering has anyone modified their box's to hold more weight. Right now mine is full of sand with 4 PVC pipes for landscape tools. I am considering adding two tubes filled with sand or concrete to each side. I'm thinking the more weight I can put back there the better. Any thoughts?
/ 2520 ballast box #2
Too much can lead to problems as well. My 3720 and 300X manuals have fairly comprehensive sections on ballast. It stands to reason that your tractor and loader manuals should too.
FWIW, my manuals indicate that basic ballast box is rated to hold sufficient counterweight to offset the loader and loader capacity on a 2000 series. The ballast box extensions seem intended to counterbalance the heavier loaders/capacities on the 3000 and 4000 series.
//greg//
/ 2520 ballast box #3
Loose the sand and add cement, Portland cement if you really want it heavy. JD also sells an extension for the top.
/ 2520 ballast box #4
what would be the result of using portland and not adding the water? does that weigh more than sand but could still be removed so as not to be as permanent as concrete? just a thought, i don't know the answer. cheers..............................bud
/ 2520 ballast box #5
I am about to fill my 2520 ballast box half way with portland cement. This way, I figure I have enough weight for 90% of what I will need the loader for, but it gives me some room to add more removable weight (steel, rocks, whatever) if needed + a little storage space since it won't be filled to the top. I also have loaded tires.
/ 2520 ballast box #6
It will absorb moisture and turn very hard...Yes it weighs more than sand.
/ 2520 ballast box #7
Hi,
I have an I-match, portland filled Deere ballast box and when needed, 5-40Lb Deere suitcase weights, that's just about the lifting limit of the 3pt on the 2x20's.
The 200Lbs of weights fit nice in the top of the box when I need the extra, one on each side, on it's side and the 3 in the center standing up. The stay in place very well so far.
Tom
/ 2520 ballast box #8
I had a couple of issues to address when I got my ballast box. I didn't want anything "permanent" in there. I also needed a place to store my 42 lb suitcase weights. I killed both birds by doing this:
I lined the box with sheet plastic. Then I placed four, 80# bags of concrete in the box with pieces of sheet plastic between each bag. This way, if I ever want to empty the box, all I have to do is smack the concrete with a hammer and it will crumble so I can remove it. The sheet plastic will act as a bond-breaker.
With 4 bags of concrete in the box, I had just enough room for my (8) 42 lb suitcase weights. This brought the total weight of the box to 809 lbs.
/ 2520 ballast box #9
The standard ballast box is quite heavy enough to compensate for any weight you can have on the front. Filled mine for the 3520 with concrete and find it rather too heavy, even with a bucketful of gravel or stones.
2017 Ford F-250 Pickup Truck (A61573)
2017 Ford F-250...
ROANOKE G195 BRUSH-AX LONG ARM MOWER (A63291)
ROANOKE G195...
2021 Kubota SVL 97-2 (A62177)
2021 Kubota SVL...
2022 EZ-GO ELITE...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
