GT2544 PTO Clutch
/ GT2544 PTO Clutch #1
Captain Ned
Colchester, VT
Managed to find a branch which stopped the deck cold and snapped the deck belt. Now, PTO won't engage. I can hear the solenoid/relay click, but that's it. Since I can't find the service manual, what's my fault tree?
Thanks in advance.
/ GT2544 PTO Clutch #2
Check to see that the key didn't shear.
/ GT2544 PTO Clutch
I did find a blown 5A fuse. I'm sorta hoping that's the cure. PTO pulley does not spin free, so the key isn't sheared. My guess/hope is that the deck belt snapping saved upstream damage.
EDIT: A new deck belt and a new fuse and all is well.
/ GT2544 PTO Clutch #7
My across the street neighbor snapped the deck belt on his beast of a (Garden Way built) Troy Bilt tractor just before he was going to lend me the tractor! Same thing. A good 6" of thick grass. When he picked up a replacement belt the counter guy said he sold at least a dozen PTO and/or deck belts for various machines today alone. It seems like it's more the mowing conditions.
/ GT2544 PTO Clutch
Well, I hope the replacements on order will work with the deck at max height. I tried to tame the dandelion beasts with the push mower and that was an instant no-go. Heck, when I snapped the last one I was taking maybe a 10" cut on a 44" deck.
By the time the ground dries out, the side hill will be unmowable.
/ GT2544 PTO Clutch #9
For my future reference where did you find that 5A fuse that was blown??TIA.
/ GT2544 PTO Clutch
There's two blade-type fuseholders on wires sticking out of the backside of the instrument panel sort of hanging over the battery. There isn't much slack so you'll need to stick your head under the hood.
/ GT2544 PTO Clutch #11
Thanks Cap'n Ned. I have a 2544 as well and figure that may save me a 60 mile trip one day. BTW I am a long time member/lurker but got a new account recently due to password issues.
/ GT2544 PTO Clutch
You're welcome. You'll find that the crowd here really wants to help you fix whatever is wrong and is very supportive of those who try to go DIY.
/ GT2544 PTO Clutch #13
I also have a 2544 also with PTO problems. I was mowing, 1 1/2 hrs, PTO just stopped. Fuse is fine, replaced anyway. Blades are clear. Checking everything I found a black wire, , looks like 18 ga. wrapped around the shaft on the engine side, sheared and frayed.
When I start the PTO, it sounds like it spins, but doesn't engage the belt-pulley. Try to spin by hand it locks so I guess the key isn't broken. No? I can't find where the wire goes, can't find a diagram on line showing the PTO with the wire, can't get it fixed - any ideas? I don't think it is just debris, but can't find other leads. Sure would appreciate anyone's help. Thanks, Sam
/ GT2544 PTO Clutch #14
The PTO wiring looks like this.
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A65643)
2008 PROGRESSIVE...
Onan 6500 Generator (A66408)
Onan 6500...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
36in AIM Bucket w/ Teeth Excavator Attachment (A64194)
36in AIM Bucket w/...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
