How LOW can you GO?
/ How LOW can you GO? #1
Ginormous
Gold Member
Dayton, Ohio
Yanmar YM2210
Here's my question: how tall is your tractor with the ROPS up? I'm going to be putting up a barn, and I want to make sure the door for the tractor is tall enough -- I plan to have a separate entrance for the tractor that takes into account the concrete pad from a barn that used to be there.
/ How LOW can you GO? #2
I have 1" clearance on my 8 ft door, although the ROPS on my tractor is not standard and somewhat taller then standard, ;)
/ How LOW can you GO? #4
Think! Will I ever have a bigger tractor? Will I ever put new tires on my exsisting tractor? Will I ever add a roof or cab to my tractor? Will I ever put new lights on my ROP? :confused::confused:
Make the door as wide and tall as your plans will allow! After it's done it's harder to make them bigger then!
/ How LOW can you GO? #5
My 2210D just barely makes it in my (standard height) garage door w/the rops up. I mean, it touches the top of the door frame as it goes through. If it was one inch higher, I would have to take the pins out and fold it down...............
Sounds like a 10' door ought to cover me... unless I get completely crazy buying bigger and bigger tractors. :drink:
/ How LOW can you GO? #7
I specified a 10' door and in reality only got about 9'10". You would be amazed at all the ways contractors will try to lower your garage door. I was there every day and I measured and cracked the whip, but I still got shorted.
I would go for 11' just to be safe...
/ How LOW can you GO? #8
wrong contractors :D I would have request 10' 1 1/2 in the rough frame opening, By the time I add the 2x8 for the encasement you would have been right on the money, well except the 3/8 weather stripping that seals the door across the top and sides,;)
I do know what you mean though, I always had to remind the framers to take off that 1.5 inches,:mad:
/ How LOW can you GO? #10
All I can say is don't add chains to the rear tires.;)
/ How LOW can you GO? #11
The bigger the door the better. :p I have no issues with over head clearance getting into the barn as we have 12' doors. :cool::p The top of my ROPS wont be hitting the top anytime soon. :p;):D
/ How LOW can you GO? #13
Actually where my tractor sleeps is in the barn and has a 10ft door, but when I do service him I bring him into my shop that has the 8 ft doors, and as long as he behaves himself I let him keep company with my other 2 lawn tractors in the shop :D
/ How LOW can you GO? #14
:thumbsup: That's what I would do.:cool:
/ How LOW can you GO? #15
Agreed, I would goes as big as you can.
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
2007 Sterling L9500 Fuel & Lube Y22693 (A62613)
2007 Sterling...
Kuhn GMD 600 (A64127)
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2022 EZ-GO ELITE...
