Front loader carryall
/ Front loader carryall #1
dooger54
I'm looking for ideas on how to add a "carry-all" to my front bucket. I did some searches and couldn't find anything although I know I've seen them here before. I need to add a platform of some kind so I can more easily transport larger items, like my pressure washer, around my property. I do have a welder. Would like something that is easy to add/remove.
/ Front loader carryall #2
I think the ones you've seen were home built items.
Take a look in the "Build It Yourself", "Projects", and "Welding" forums.
/ Front loader carryall #3
Not sure what kind of tractor you have, but I have quite a few posts regarding building my carrall and setting up a loader-mounted quick hitch that might give you some ideas. Search for my posts in the Build It Yourself forum.
/ Front loader carryall #4
You could use a set of forks and build any type/size carryall you desired out of wood.
Or use a loader mounted receiver hitch and slide a conventional carryall into it.
You could also get a a 3pt carryall from tractor supply for small money.
Here's one monster box I built to handle leaves, also makes a nice work platform for reaching higher places. but this does require you to have the forks.
JB
/ Front loader carryall #5
I took 2 pieces of C-channel, and notched them to slide over the bucket, like forks. Then I can put plywood over them to make a large flat work area. You may want to re-enforce the sides if you intend to use them on very heavy loads. The nice part was, the materials cost very little.
My tractor is a NH 35 with 6' FEL. I wanted the platform to load from the front so I could keep another implement on the 3pt hitch. Seems like my sprayer or something else is always attached to the rear.
I hadn't thought of the other forums suggested. Will do a search for on those also.
/ Front loader carryall #7
I have the same situation. I really like being able to just grab the carryall on the front and go, without having to drop the mower, chipper or whatever is on the back.
/ Front loader carryall #8
Thats Nice! :) The whole dang work bench! ;)
I like it cause the older I get the less I like working on the ground, this way I got a small bench to work off of!:thumbsup:
/ Front loader carryall #9
That is very nice!! You're set up for the whole day!!
Is that box on forks, or did you build a QA hookup on it?
Runner-
Do you have posts anywhere showing how you constructed that??
/ Front loader carryall #11
I'm assuming Runner has forks.
With forks like I mentioned you could build anything you wanted out of wood. From something as simple as a pallet with sides, to entire work shop, as long as you can still lift it.
JB.
/ Front loader carryall #12
That is a neat setup! As others have asked, is that box on forks, or did you build a QA attachment?
And what's with the hitch receiver under the front edge of the box? You planning to haul garden implements and tow a trailer at the same time? :D
/ Front loader carryall #13
"That is a neat setup! As others have asked, is that box on forks, or did you build a QA attachment?
I modified a HF quick hitch to fit on my loader mounts.
You are correct, Sir, that is a receiver hitch on the carryall. You bet your britches that I do pull a trailer with it in that configuration...
/ Front loader carryall #14
And what's with the hitch receiver under the front edge of the box? You planning to haul garden implements and tow a trailer at the same time? "
That's great! so you could use it on the rear as well. I see you have another adapter between the QH and the carryall?
JB.
/ Front loader carryall #15
JB
I would spend the time building forks and the use pallets as a basis for a carry-all
I use my forks all the time
There are many great suggestions on how to build forks
I spent less than 40 bucks building mine
I've even used for brush I use all the time for logs I put everything I can on pallets now and move and store that way
My forks are two of my most used attachments
My 2 cents
Good luck
Joel
/ Front loader carryall #16
My 2 cents
Good luck
Joel
I agree, even though I didn't build my own and mine cost close to a grand, I still do not regret it.
Though I got mine when I ordered the tractor because I had an immediate use. If I had known about all these homemade plans I might of gone that route to save some green.
JB
/ Front loader carryall #17
"That's great! so you could use it on the rear as well. I see you have another adapter between the QH and the carryall?"
Yes, the "adapter" is also a trailer hitch. I made the adapter because my KK carryall and rake are not quick hitch compatible. One of these days, I'll probably modify them, but the adapter seemed like the easy solution at the time.
/ Front loader carryall #18
...and to those asking about the carryall build thread... I thought I did one, but the only one I found was this:
http://www.tractorbynet.com/forums/customization/144060-modified-king-kutter-carryall.html
After that one, I built the sides and seat and I'm not sure I posted any pics of that process, maybe they're scattered amongst other threads so here are some. The steel stakes on the sides are "nested" so top tube slides into the bottom tube and the bottom tube slides into the "stake pocket" which is another tube. I don't like bolts sticking out to snag things, so I drilled holes in the tubes to recess the ends of the bolts.
The seat is reinforced with some old bed rails, just to keep it from sagging and racking from side to side. The seat and each of the side and end pieces are removable.
The receiver hitch is just cut-down from one that came off a car, bolted between the "forks" of the carryall frame.
SET OF (10) ACE CATTLE PANELS W/CONNECTING JOINTS (A60736)
SET OF (10) ACE...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
207276 (A52708)
207276 (A52708)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
66'' Skid steer bucket (A61567)
66'' Skid steer...
