Front loader carryall
/ Front loader carryall #1
dooger54
I'm looking for ideas on how to add a "carry-all" to my front bucket. I did some searches and couldn't find anything although I know I've seen them here before. I need to add a platform of some kind so I can more easily transport larger items, like my pressure washer, around my property. I do have a welder. Would like something that is easy to add/remove.
/ Front loader carryall #2
I think the ones you've seen were home built items.
Take a look in the "Build It Yourself", "Projects", and "Welding" forums.
/ Front loader carryall #3
Not sure what kind of tractor you have, but I have quite a few posts regarding building my carrall and setting up a loader-mounted quick hitch that might give you some ideas. Search for my posts in the Build It Yourself forum.
/ Front loader carryall #4
You could use a set of forks and build any type/size carryall you desired out of wood.
Or use a loader mounted receiver hitch and slide a conventional carryall into it.
You could also get a a 3pt carryall from tractor supply for small money.
Here's one monster box I built to handle leaves, also makes a nice work platform for reaching higher places. but this does require you to have the forks.
JB
/ Front loader carryall #5
I took 2 pieces of C-channel, and notched them to slide over the bucket, like forks. Then I can put plywood over them to make a large flat work area. You may want to re-enforce the sides if you intend to use them on very heavy loads. The nice part was, the materials cost very little.
My tractor is a NH 35 with 6' FEL. I wanted the platform to load from the front so I could keep another implement on the 3pt hitch. Seems like my sprayer or something else is always attached to the rear.
I hadn't thought of the other forums suggested. Will do a search for on those also.
/ Front loader carryall #7
I have the same situation. I really like being able to just grab the carryall on the front and go, without having to drop the mower, chipper or whatever is on the back.
/ Front loader carryall #8
Thats Nice! :) The whole dang work bench! ;)
I like it cause the older I get the less I like working on the ground, this way I got a small bench to work off of!:thumbsup:
/ Front loader carryall #9
That is very nice!! You're set up for the whole day!!
Is that box on forks, or did you build a QA hookup on it?
Runner-
Do you have posts anywhere showing how you constructed that??
2015 MACK GU713 DUMP TRUCK (A59823)
2015 MACK GU713...
2018 ALLMAND MP40-8BI-PORTABLE DIESEL GENERATOR (A59823)
2018 ALLMAND...
2020 Sellick S80 (A60462)
2020 Sellick S80...
(2) Firestone 420/90R30 Clamp on Duals (A60463)
(2) Firestone...
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
2025 Ford Transit Cargo Van (A56858)
2025 Ford Transit...
