New tractor sitting outside?
/ New tractor sitting outside? #1
VTtractorguy
Vermont
Still looking...
Hi all. I'm still deciding on what I can afford for a new tractor (2305 or 2520). A local dealer has a new 2305 left, but I'm skeptical about pursuing it because it's been sitting outside at the dealership since October (so roughly 7 months now!) With our drastic Vermont weather, I'm not sure if leaving it out has set it up for premature rust and/or other problems. It has about an hour on the meter.
What do you guys think?
Thanks for your help.
/ New tractor sitting outside? #2
I guess it would depend on what type of deal they would give me. You may find a few things have early problems (like the blinker switch making the blinker blink unexpectedly). Most would be cosmetic such as shift knobs and fuel cap being sun bleached.
If they want premium b/c of limited avail nationwide and you can still get the smoking deal on the 2520, I might be tempted to go that way (no know all of your use situation)
If they are giving you a great deal to move it before the 1023/1026 arrive, and it fits you need, I wouldn't worry about it too much, as long as the hood paint looks good. I would run it around a bit and check hyd. oil and front geal oil for emulsified water. Sometime when they sit they seem to pick that up. Also ask them to drain the tank and replace the fuel filter (only an $8 part, just saves you the effort) in case any water/condensation is iun the tank from sitting so long...
/ New tractor sitting outside? #3
Tractors set outside on dealer lots and the manufacturing facility for months. They're built for outside.
I wouldn't worry about it...
/ New tractor sitting outside? #4
Cars trucks etc. outside some longer than year fine...when own tractor will feel winter but under more stress.
/ New tractor sitting outside? #5
Don't worry about it, many tractors sit outside all their lives.
/ New tractor sitting outside? #6
I wouldn't worry about it, but we own a 2305 and I would go with the 2520 if I had it to do over.
Yes, that's what I really want to do. It just comes down to dollars & cents. I was also considering the 2320, but with the current promotion, dealers are telling me for around a $1000, I can jump from that to the 2520 (really a no-brainer). But there is a significant spread from this left over 2305 to the 2520 and that's what I'm wrestling with. :confused2:
Thanks all for your help. :thumbsup:
/ New tractor sitting outside? #8
Well, this might change what you do. The 2305 is no more and hasn't been available for months. It's replaced by the mythical 1023e.
The 2320 can still be found on dealers lots but is also going away, replaced by the 1026r ( or so the dealer has said).
The 2520 is very alive, but unobtainable. Dealer checked again this morning, Deere is now saying mid august delivery.
2720 is very available. Many dealers have one on the lot. Deere has just over 300 of them in inventory and they can be delivered inside a week. It's just not sitting at a great price point for them.
Oh, and don't worry much about a tractor that's been sitting out for bit on the lot. I think you will be fine with it. Honestly, if it has the capabilities you are looking for, then it isn't necessary to go to the bigger tractor. Excess capacity is just bragging rights that won't pay the bills.
/ New tractor sitting outside? #9
Someone else posted here earlier that the 2520 deal requires the purchase of a couple of implements? Thus, in their math, the net savings, while good, were not a straight-forward wad of cash savings. Is that right?
And... Because of the promotion on the 2520, the inventory, in their area was nill and causing a 2-3 month waiting period. If your dealer has a 2320 or a 2520, you'd might want to take a look and see what the monthly difference would be. I'd bet it might be less than you think.
/ New tractor sitting outside? #10
As a past owner of a 2305 and present owner of a 2520, I'm more curious about the actual work you want to do with the machine than the cost of ownership. I would recommend letting that drive the decision first, then work on the economics. How much and what kind of land? What tasks are planned? etc.
/ New tractor sitting outside? #11
I wouldn't worry, as others have said, they head outside as soon as they roll off the line, and generally they don't go back inside until they are sold! Which can be upwards of a year by the time they get to you. Part of the dealers job is to 'pre-deliver' the tractor, this means going through it with a fine tooth comb and fixing up any manufacturing problems and lot/ storage/transport defects. This includes replacing bolts, panels exe... What ever is required to get the unit back to as-new condition. This process often doesn't happen till the tractor is sold. So with the exception of major defects what you see in the dealers yard is often how the manufacturer sends it, rust included!
/ New tractor sitting outside? #12
I keep my Kubota BX outside. Once a month I do a through inspection of wiring and electronics to make sure field mice and squirrels aren't ruining my toy/tool.
Just keep it out of direct ran and sun.
/ New tractor sitting outside? #13
Sure tractors can sit outside their whole lives, just like cars, but you tell me how much better a car looks after 5 or 10 years spent garaged as opposed to one that's been outside. I spent $1000 on a metal carport and expect that I will get that back should I ever sell my tractor. I also don't have to clean off bird poop, tree sap etc.
/ New tractor sitting outside? #14
First I have ever read that...and I don't believe it. The 1000 series are way smaller in size compared to the 2000 series.
/ New tractor sitting outside? #15
as an owner of two 2305s and a 2520, i would say that the 2305 is the best lb 4 hp in the line, after 600hrs on the 2005 we have, i wouldnt trade it for the world, i like the 2520 because it does thing a little faster, stronger, but for the money, the 2305 is nice.... just my 2 cents.
btw, as soon as you get one, get chris's pallet forks, one of the best things i ever got! :thumbsup::thumbsup::thumbsup:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED KJ 33'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 33'X25'...
2008 Mercury Grand Marquis LS (A62613)
2008 Mercury Grand...
2010 International 7400 Service Truck with Crane, VIN # 1HTWGAAR6AJ276531 (A61165)
2010 International...
2014 Toro Workman MDE Electric Utility Cart (A61567)
2014 Toro Workman...
Kubota KX057-4 Excavator (A61166)
Kubota KX057-4...
