gator blades
/ gator blades #1
ipwanab
Southern Indiana
Kubota Grand L3560
Guys, does anyone have experience with gator type blades on 62d mower? My stock blades do okay when grass is dry and short but lately its been wet and a foot tall. The mower cuts the grass but the discharge looks like the highway department has been through. I have read that these blades will discharge a smaller clipping but I am very wary of those claims. I can not really go over my cutting more than once due to damage because the yard is so soft from all the rain. Anyone already figured this situation out?
/ gator blades #2
Let me preface by saying that I have limited experience with gator blades.
But I did put them on my 261 RFM last fall.
They seem to discharge smaller clippings as claimed, especially with the dead leaves that fall, but I also noticed they appear to have a lot less lift than a typical hi-lift blade. So grass that has been ran over or is laying down, doesnt stand up and cut as well as a standard hi-lift blade.
Also, I noticed when buying mine, that there were the "gator" brand blades and then there was a knockoff brand. The knock off brand had the mulching wings angled the opposite way:confused2:
The way these blades work is NOT by having those gator "teeth" chop stuff up. Rather they are angled to throw the chips back towards the center of the blade and be chopped up again that way. The knock off blades had the "teeth" angled outwards, so I dont see how that would benefit
/ gator blades #3
I bought some for my 2320 last summer, to put on my 62d mid mount mower, they work great for me. I used to have problems with long wet grass, always looked like I was getting ready to bale hay. So I went over to my local JD dealer and he ordered me a set. I will NEVER go back to the original blades. The gators are doing the trick for me. Yes they do produce a finer clipping, and I believe the quality of cut is much better also. Hope this helps. You won't regreat getting them:thumbsup: Let us know how you like them.
/ gator blades #4
Oops, tried them on my Toro commercial Z-Master, took them off and gave them away. Hi-Lift for me.
/ gator blades #5
In this situation, it's not going to matter what blade you use,you are going to get clumps. I have the Gators,and love 'em. Don't know about high lift blades,but maybe I'll give them a try at some point too.
It has been raining off and on every day here for this whole month so far. Last Sunday I had a "dry" 5 hours in the afternoon. I cut the old 4 acre pasture. I cut as much water as I did grass.:) The grass was average 6 inches high. When I was done,there were just a few small clumps here and there. IMO,these blades are awesome.
Beaten down grass from day after day of hard pounding storms and it cut as if it was a nice dry sunny day.:thumbsup:
Greg
/ gator blades #6
Six of one, half dozen of another from my experience with the gator blades. I don't have them on my deck that has the blower for picking up clippings and leaves. Just don't work as well.
On my deck for mowing I have the gator blades and in early spring grass for first cutting, they don't pick up the new grass well for getting a good cut. Later in the summer, the grass seems to stand up better and I get a better cut and no clumping.
Plus for the gator blades is they stay sharp longer and are tougher when handling heavy sticks.
I've heard that Bailey's has a good price on gator blades, even when including the shipping cost. I've seen them in their catalog and online, as I buy chainsawing and logging items from them.
/ gator blades #7
Put them on my 62C last year. Definitely chops the clippings into smaller pieces to discharge. Definitely does not have the lift of the stock blades so you leave longer grass where the tires drove over it. I just go back over it a tire track width over in the opposite direction. Definitely chops up leaves. I like them but prefer the stock blades when mowing the 3 foot tall grass in my back field in late June and mid-September. Also, the gators are a little noisier than the stock blades but I wear hearing protection so it doesn't bother me...
/ gator blades #8
Hmmm,mine doesn't do that. Like I stated,wet or dry,cuts the same. Maybe I have an oddball deck and tractor combo,because it's cut is awesome.:)
Greg
/ gator blades #9
Greg
Good point, the deck design does make a huge difference.
/ gator blades #10
The kind of grass affects it too.
/ gator blades #11
The gator blades on our 455 with 60" deck have worked out very nicely for the past couple of seasons. I definitely like how they cut and chop up the clippings into tiny pieces- when mowing tall grass there is rarely a need to rake the clippings/debris.
Haven't noticed any difference in cutting extremely tall field grass compared to the oem blades either- both cut pretty well as long as they are sharp.
If I didn't already have a spare set of 48" oem blades for our GT275, I would love to have the gator blades on that also. However, when running a mulching blade on a lower power/less toruqe engine, you might be more prone to clogging/bogging down.
/ gator blades #12
I'm running a 425 with the 54" deck. It is my experience also that when the grass gets too tall the gator blades can't make the clippings disappear. We also have a F525 which is 17 hp with a 48" deck.The gators work fine on the F525 with very little clogging except in extreme conditions. We will see today. It is the 9th day since the last mow and looks like it will be wet.
Chris
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A63689)
2022 Greenworks...
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61574)
2012 23ft...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
Carryall 1700 4x4 (A61574)
Carryall 1700 4x4...
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
