Chinese Dozer problems
/ Chinese Dozer problems #1
DozerPaul
Massachusetts
Chinese Dozer D326RT, 2005 Cat277B, 1976 Ford 6500 BLT
Hi, just hoping to gain some insight into the problems with my Chinese dozer.
I believe it is a 2002 DH320RT by Guilin. 2 problems:
1) Transmission fluid streams out of a small hole on the bottom of the starter housing. It stops after machine is at operating temp... This is a nuisance issue as I maintain proper fluid level. I'm tying to determine how much of the machine need to be torn down to locate the bad seal, any ideas?
2) Dozer will not crawl and makes a grinding sound if put in any gear and does not matter if clutch position. I'm trying to determine if it is transmission or final drive, any ideas?
Thanks, -Paul
/ Chinese Dozer problems #2
Hi Bob, thanks for your reply... no, not ATF I should of said fluid... It does have a hydraulic shuttle clutch... My machine looks exactly like the machine you have pictured... The dozer is 100 mile from my home on a property we have in western Mass... I was planning to bring it back for repair this summer.
Thanks, -Paul
Sorry, I have a parts manual for a Yuchai dozer, not sure if is exactly the same.... Thanks...
TAYLOR S/A LOOSE LEAF TRAILER (A64278)
TAYLOR S/A LOOSE...
EZGO (A64557)
EZGO (A64557)
Engine knock
Engine knock
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A64557)
2005 Freightliner...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
