RobertN
Super Member
I just bought a used Deere "32" 3pt splitter. Before buying, the seller hooked up to his tractor, and we split a couple rounds of oak. Worked perfect.
Yesterday, I had everything hooked up, with a little help from Jinman and the NH forum. I'm trying to run this thing on a NH TC40D.I had to extend the hoses. While I had the hoses off, I moved the ram in/out and got most of the old fluid out. It(fluid) was clear and clean. Once hooked up, I cycled the system back/forth to make sure fluid flowed, and hopefully purge the air from the system.
Now, when the cylinder retracts, the valve does return to center. When the ram is fully retracted, the back side of the valve, spurts fluid. In the picture of the back of the valve, the red arrow points to a sleeve. When the ram is retracted to its limit, that sleeve move out 1/4-3/8", and fluid flows out(all over back of tractor). Not under super high pressure, but enough to spray the back of the tractor.
With the valve in the center position, the ram is moving out(extending) now. Not, under full pressure; it stops easily against a log. Then when I push the lever to split, it splits the log.
I have only run up to about 1500-1600 rpm on the tractor.
I am not sure what is happening. My only theory, is my tractor has better flow(9.8gpm) then the other guys JD( he said 5 gpm for his tractor). Maybe I have enough flow, that it took out some weak seals in the valve?
Any idea what to do? Can seals in the valve be replace? O-rings?
There are no make/model numbers visible. Guessing will have to unbolt it and look underneath?
Even with it leaking, it split nice. I split up a few oak rounds, that were about 18" across. Even at low rpm on the tractor, it split those rounds easily.
