B2920 HST Creaking Sound
/ B2920 HST Creaking Sound #1
e171fish
Member
The transmission on my new B2920 is starting to worry me a little bit. It's making a loud creaking type noise when going up slight inclines or working with the box blade. It's in low range, 4wd, with the BB and FEL attached at around 2700 rpm. It's not being worked hard at all.
I'm familiar with HST whine from my BX2360. This doesn't appear to be the typical HST whine.
I have an audio file but I guess it can't be uploaded to the forum.
Any guesses? Normal?
On a positive note I just installed a Tuff Top Canopy and the Kubota Quick Attach. Pretty happy with the results.
/ B2920 HST Creaking Sound #2
Tighten the wheels and hubs
/ B2920 HST Creaking Sound #4
another vote for wheels making the noise.
James K0UA
/ B2920 HST Creaking Sound #5
If the creaking sound is still there after tightening your wheels and hubs, try removing your FEL and go up the same incline and see if you still hear it. I've had a weird creak sound in the past and it ended up coming from the left side of the FEL where it mates up with the tractor.
/ B2920 HST Creaking Sound #6
If it is creaking metal noise...
1, Lug nuts
2. If it has the same adjustable axle the 7510 /7610 has tighten up on the inside of the axle.
I thought I had broken gears- on my 7510- Panic stricken..
I posted here and the folks saved my bacon !!!!
Good Luck.
RD
I'll check the wheels tomorrow and post a youtube video if its not resolved.
Thanks
/ B2920 HST Creaking Sound #10
Yeah, that is some kind of contact. You've not been able to locate it? Sometimes those things can be difficult because the sound gets transmitted through other things, as a distraction.
Sakai SW354 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Zero Turn Mower (A59231)
Zero Turn Mower...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A59823)
2015 FORD F-150...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
