3-Point Hitch 169D 3 point hitch is weak
/ 169D 3 point hitch is weak
Got my parts from Hoye last night. I found out that the hydro filter i got doesn't go on my Yanmar but it might fit my log splitter. I also got the manuals for it, 3 oil and fuel filters, a new head light bulb which I already have installed, and the oil pan gasket as my oil pan has a leak since the gasket has gone bad due to weathering. Now, tonight I am going to possibly take on one of the tasks but it is between servicing the engine (have to replace the oil pan gasket in the process which the oil pan has over 20 bolts holding it on), or servicing the tranny which means my tractor will have no fluid in it for over a day as i do not have an air compressor so i will have to blow out the hydro screen at my grandpa's place. So what do y'all think? Service the engine tonight or service the tranny?
/ 169D 3 point hitch is weak #42
Do both! You can pull those bolts in 20 mins and drain the Hydro flid in a 5 gallon pail all at the same time. By the time the pan/plate is off you can pull the screen and then clean up the pan and screen at the same time in a bucket of water soap and degreaser or bucket of deisel or gas. Lay the screeen to dry dry the pan/plate. Put the gasket and or sealer on and bolt the plate up and let it dry for a day then go to Gpa's and blow the screen if needed. Then when you get back put it back in and fill both sumps with oil.
Last night I serviced the engine. When I got to the point with the oil pan I couldnt get the right socket extension to fit in all the places between the pan and the 4wd shaft. I did notice that I had a bit of loose bolts so I tightened them all up. I regret not putting in the new gasket but it was just how it worked. I will have to do that next time. I also replaced the fuel filter, quite a job. There is a switch on the filter assembly that holds the filter on and the fuel bowl and the switch would not hold back the fuel. So basically I had to go very fast and switch from the old filter to the new one, put the bowl back on, and tighten it. I went from a full tank of fuel to a 3/4 tank of fuel within 60 seconds. :( I had Diesel all down my arms and I have to say that it is sure a challenge to wash the smell off. When I got the engine all serviced and the new oil in it sure runs smoother. :thumbsup: Drove it around the yard to make sure everything was sound and it just purred. :) One challenge i had was that the only record I have for service was it was serviced in 6-09 so I have very little record on how it was maintained. The last service did not include the hydro though. Just the engine.
/ 169D 3 point hitch is weak #44
Jake,
Next time just pinch the fuel line and it wont leak fuel all over..
Write the Date & hrs on the oil filter.
Ernie:D
/ 169D 3 point hitch is weak #45
Jake,
Ernie:D
I was going to say that, but u beat me to it. I was going to say use vice grips on it. A tip i read from someone on here was to use small pieces of a paint stirrer, say 2" cut pieces around the fuel line so you dont damage the line like just vise grips may do.
/ 169D 3 point hitch is weak #46
I have used a 1/2" straight PVC pipe connector when I didn't have locking pliers. Bend the line in half, stick it into the connector. The crimp in the line blocks the flow. Poor guy- we've got a bunch of ideas for him after the fact...
JohnDeere3720, have you been able to figure anything out on the weak lifting capacity yet?
/ 169D 3 point hitch is weak #47
Hes waiting till he gets to grandads to take his screen out of the hydro. He is hoping that the screen is plugged. Hes going easy first so i doubt he is messing with anything else.
You nailed it there. I will hopefully get my tractor to my grandpa's this week and get it all apart.
Jake,
Ernie:D
I will have to do that. I also am working on making up a service chart to show what I have done service wise to it. :thumbsup:
/ 169D 3 point hitch is weak #50
The service log is a good idea. I write the date and hours when I change the engine oil and filter, but the other service items don't have an easy way to mark. Having a log, in paper and/or electronic form is smart. If you ever decide to sell your machine(s), having the logs in that manner make it a lot more appealing to the purchaser as well, and worth more money to you. I like it.
Well I just got my tractor down to fix it this week. I brought it to my Mom's cousin whom has all the tools I will need to get it fixed up so I will be down there working on it until it is fixed. :)
I got one question, if the hydraulic screen is not the issue, where do i turn to look? I need this fixed ASAP. :)
I just found something out about my 3 point hitch strait out of my manual.
TractorData.com Yanmar YM169 tractor information
It lifts over 1100 pounds! :cool: I guess i exceeded that when the 3 point over loaded with the boxblade full of dirt. :(
Just made a new service chart. :thumbsup:
/ 169D 3 point hitch is weak #55
/ 169D 3 point hitch is weak #56
I am not sure the figure for the YM169's lifting capacity is accurate. The YM186, the next step up, basically, is listed to somewhere around 551lbs, though that's 24 inches back from the lift point, and 661lbs at the lift pins. I've read that the YM169 is similar to the YM1401; my 186D is much stronger in lifting capacity than my 1401D. Maybe the 169 is significantly stronger than the 1401? It's listed as being quite a bit heavier on tractordata.com.
I thought it was a lot too. But thats what the manual says. :confused2:
/ 169D 3 point hitch is weak #58
Unless your BB is totally different than mine you did not overload it. Thats Lifing Lbs not pulling lbs. Unless you have gumbo sticky clay when you lift a BB the dirt will stay on the ground, at least thats how mine works? So your only lifting the weight of the BB itself. The tractor can pull way more than 1000lbs with the lift arms this is different. Just think of like a hay wagon, the thing it self weight more that 1100lbs and you can move it. My tractor moves my 16ft carhauler that weighs something like 1200-1500lbs like its not back there!. Can tow my 3000lb plus boat like its not back there. Im thinking you may have the capacities mixed up some. Not doubting the book said what it did i just htink your thinking about it wrong.
Even if you did overload it with something to heavy, it has a release valve that pops to keep you from tearing up the pump or blowing out the seals in it.
It happend basically when my box blade packed full of sticky wet dirt. We have a clay type soil here and it likes to stick to most everything when it is wet. It did go to the by-pass valve but not it basically gets a little pressure to the 3 point but after a certain amount it goes to the by-pass and the engine bogs down a little. Could i have a seal out and it is caught in one of the lines? That could be a culprit that only allows a certain amount of pressure to be exerted to the hitch.
/ 169D 3 point hitch is weak #60
After 6 pages I encourage you to go back to post #6 and try this test. Based on the suddenness of your problem I do not believe your problem is your fluid and screen. Not saying it doesn't need to be addressed. I have read more than 1 thread of a sheared pump key and the friction between the pump coupling and drive shaft turning the pump enough to put up just a little flow. I cannot see how you can do harm if you try my suggestion. :thumbsup:
