jd 445 steering cylinder
/ jd 445 steering cylinder #1
toyfarm
Member
Connersville, In.
2013 Kubota B3200
Anybody point me in the direction for one of these for less than $270
I prefer used in good shape but open to new at a reasonable cost!
John Deere part number is AM118796
/ jd 445 steering cylinder #2
What happened to the cylinder? Not repairable?
well for one it don't appear to be re-sealable (welded shut) for 2 it turns much sharper one direction than the other and for 3 it appears to be leaking thru the casting around the seal and not the actual seal! So i assume i'm looking for a replacement?
/ jd 445 steering cylinder #4
Unfortunately JD uses welded cylinders on a lot of smaller tractors, and they are "non-standard" forcing you to buy a replacement from them. My only suggestion would be to find a local shop and see what they can do for you.
unfortunately there are no hydraulic cylinder shops within 70 miles of me! by the time i do all the runnin around and chasing a better deal, more than likely be better off to bite the bullett right off the bat??
/ jd 445 steering cylinder #6
I'd prolly do that too.
Thought you might find one on eBay from someone parting out a 4xx. Didn't see any listed now, but some different sellers look like they have some parts and might be worth a contact or two.
i've been all over ebay...this one in particular i contacted seller asking if it would interchange? There are 3 diff. ones that fit 445 alone (depending on serial number) so i would want to make sure that it would interchange! Still no return msg from seller. Also there are not several as this is the only one i found that was even close! There have been several in recent history that have sold though, perhaps I should mow with the big ole Kubota until one can be located reasonably?
/ jd 445 steering cylinder #9
The 420 is a different frame tractor from the 425, 445, and 455. I would be very suspect of a 420 steering cylinder for your 445. Among the 445's are the AWS that likely take a different steering cylinder. Ask for the measurements, as it might be easy for a seller to say yes and then the "not-so-much-fun" would begin. ;)
/ jd 445 steering cylinder #10
They are repairable with a lathe and the proper welding equipment (TIG)
The butt plate needs to be machined apart (opposite side of the rod)....then rebuild, reweld and test.....Done......
They take standard seals internally.....
i considered trying that, but never rebuilt a standard cylinder before, much less one of these. Then the other question would be, where to get the parts?
/ jd 445 steering cylinder #12
Unfortunate for you but you'd have to travel 70 miles to that hyd repair shop to get seals....JD doesn't stock them that I know of....
Just to update... bit the bullet and went local JD dealer. They were kind enough to match the price of online dealer for $253 not a great deal, but better than the $275 they wanted!
Thanks for all your input and suggestions!
/ jd 445 steering cylinder #14
I was just going to let tall know I offer the seal kit for this cylinder. Am118796. I also rebuild this cylinder for 174.88. Maybe this will help. Take care. 828-443-8023
/ jd 445 steering cylinder #15
