hydralic oil?
/ hydralic oil? #1
kubotalinc
maine
ck20
what viscosity hydralic fluid does my ck20 hst take?
/ hydralic oil? #3
We use the Shell Donax TD for all of our service work. It is 10W30 Trans/Diff Fluid.
/ hydralic oil? #4
What does the Manual say?
Maybe he does'nt have the manual. My farther bought a CK20hst to use as his all terain wheel chair/carry all, now it is time for it's 1st service and for the life of me I can't find his manual !
/ hydralic oil? #7
I've been able to get the Shell Donax TD. It works well at 0'F to Summer temps. Here are a few others Suggested from Kioti. You want to stay with a 10W-30 multi-weight for best performance. Shell Donax TD, Texaco TDH oil, Exxon Hydraul 560, Exxon Torque Fluid 56, Pennzoil Hydra Tranz, Mobilefluid 424, BP TracTran UTH, Citgo Mystik JT-5 Universal. I don't know the weight of all trac or high guard. As mentioned, it has to be trans/diff/wet brake/common sump rated.
/ hydralic oil? #8
Hi y'all. First time in this section. Normally at the Cub Cadet forum..I borrowed my SIL's 2004 Kioti CK20 standard transmission. She can't find the OM so I have been hunting down info. Almost no info on the net..
I did find a sight glass on the lower right side about mid point. Think that is for the xmission fluid..Looks a tad low. Does anyone know what they put in there originally and can I top off with another brand??
It has 86 hrs on it so not ready for a change yet.
Thanks for any info y'all can provide...
Moe
/ hydralic oil? #9
The gear trans and hydro use the same type fluid. So all of the above would apply. I don't know what brand of oil it came with originally but as long as you stick with one of the above mentioned or another hydraulic 10W-30 oil, you'll be fine.
/ hydralic oil? #10
I just changed my hyd/trans oil and used mobile hydraul extra. I talked to Exxon Tech support and i can remember what viscosity it falls under but it was very broad. He said it would work great in my southwestern Ontario Canada climate.
/ hydralic oil? #11
Can I use Shell rotella HD universal tractor fluid for transmission hydrualic & wet brake. I have not been able to find the other brands listed, but i do have Mobil 424 but a Kioti dealer told me not to use that in my CK 20 hst tranny.
/ hydralic oil? #12
I use Shell Donax TDL in both my DK45SEC HST and my CK30 gear. The TDL is better than the TD for the cold winters we have around here.
(2) HARROW DRAGS FOR WINGS (A63291)
(2) HARROW DRAGS...
Caterpillar 966G/972G Wheel Loader Service Manuals Vol. 1 and Vol. 2 (A63117)
Caterpillar...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2022 John Deere 1795 Planter (A63111)
2022 John Deere...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
Lot 602 (A62613)
Lot 602 (A62613)
