Ground Clamp Differences
/ Ground Clamp Differences #22
I'm no expert, but I think it's Bull when they say grounding prevents shocks.
Why I say that is. I've gotten shocked by a grounded electric motor when I touched it.
The hot wire had come loose and was touching the metal. Yeah the electricity probably took the path to the ground through the ground wire. But it also took it's path to the ground through me.
Don't be fooled to thinking the ground wire is gonna completely protect you.
Chad
/ Ground Clamp Differences #23
LOL
AH K0ua I looked at your profile and saw engineer and it all made sense, it was either that or highscool science teacher.:laughing:
I could point out that it is all theoretical anyway as neither electron nor conventional current flow are anything but really convenient models and until we can watch electrons actually jump they are still for the most part only proven mathmatically and not irrefutable.
Tell me this why is it critical that parallel conductors be as close to the same legnth as possible and what is the danger if they aren't?
I hoped my last bit was sufficient to say one ground is enough just make it a good one.
As for Chad if you got a shock off a grounded motor it either was a poor ground or you were a better one (you know sweathy palms stanking in a puddle with bare feet ask K0ua). The ground is not only your best defence it is usually your only defence as neutrals are not case connected. Trust me you are way safer with than without.
Back to K0ua this is all in fun so if I offend my apologies:laughing::thumbsup:
/ Ground Clamp Differences #24
I am not an electrician, but am a pretty fair welder and have been doing it for over 40 years. A ground doesnt have to be close to your work unless you are welding on equipment with bearings in it, then the accepted practice is to put your ground on the away side from any bearing so the current travels toward the ground. The resistance in the cable would make you have to turn up the amps as you moved away from the welding machine with you electrode. Most construction welding machines have only 50 feet of ground and Miller 8 bank welders can be universally grounded from one point for all machines and they still work well as far as welding goes. As long as your ground point is good and not arcing, you can be 1000 feet away and weld will be just like you are at the machine with the exception that you may have to run the setting on 300 amps to get 100 at the stinger end. The analagy of touching the battery post and stealing current from the lights is nothing more than adding another circuit. You can think of it as the power grid and you can run as many circuits as your want from it till it runs out of power.
/ Ground Clamp Differences #25
Exactly. That is the point I was trying to make with the long winded post. As everyone knows we can have parallel paths for the electrical service and it all works fine. The overall load resistance from the point of view of the source is constantly lowered as you add more loads. And in each load the current will be following Ohms law.. It is not just a good idea, it is the Law:laughing:
James K0UA
/ Ground Clamp Differences #26
Chad
doesnt make sence. if the hot wire had come loose and was touching the metal, and if the metal of the motor was properly grounded, then the return path would have opened the circuit (thrown the breaker).
The motor was not grounded. your touching it grounded it.
/ Ground Clamp Differences #27
LOL
you say engineer like it's a bad thing... :)
soundguy
/ Ground Clamp Differences #28
soundguy
I banterred whether I should reply to this or not.
I have been an industiral electrician for a lot of years and haven't been on the tools since 1999. Since then I have run a couple of maintenanace departments, worked as a consultant in the oil and gas industry, and my current roll as process control manager. I have worked in many industries and have a lot of experience. As you can imagine in those roles I have dealt with many an engineer. Now you have to take this as an attempt at humor with one foot solidly grounded in reality.
1. For every good engineer there are two bad ones. Look left look right if you don't have a dummy on both sides guess what...
2. What do engineers use for contraception.....their personalities.
okay now that I got that out of the way as I said I have worked for and rode herd on many engineers. I know some really good engineers, I also know some stuffed shirts who know diddly and hide behind white paper. Just cause it works on paper doesn't mean it works in the real world.
Being an engineer isn't a bad thing many is the day I wish I had gone back to school and become one. I didn't but as I am very good at what I do which is automation I have done well. To all the good engineers cudos, to the over educated stuffed shirts, out of the way leave it to the pros.
I hope that answers your question without seeming like I am an arrogant goof. Some people call a spade a spade, I call it a shovel and hit people over the head with it LOL
/ Ground Clamp Differences #29
In this part of the country, the difference between those clamps is...........
About $8.00
(bwahahahahhha, snicker, chuckle, snort, gefaw)
Wyo
/ Ground Clamp Differences #30
10$ delta at tsc.. :)
soudnguy
/ Ground Clamp Differences #32
Well Grayson, I have only been an Engineer for 11 years. 21 years before that as a Technician in the telephone industry. Before that a Technician in a 2 way radio shop (General Radiotelephone ticket) and an Amateur Radio Operator (Extra class) for 40 years this summer. For what little all that is worth. Yes I am a nerd, but I have never relied on my personality for contraception.:D But anyway, I have picked up a few things along the way but have never considered my self a "stuff shirt" more like a " tee shirt". But I tell you what, if you would like to learn a little more about some of the more interesting electrical phenomena like lightning, give me a call some time, as I believe I could tell you a thing or two. :)
Best Regards
James K0UA
/ Ground Clamp Differences #33
de ke4rrd
73's
soundguy
/ Ground Clamp Differences #35
just a bit.. :)
pine trees love it.. :)
soundguy
/ Ground Clamp Differences #36
Best Regards
James K0UA
LOL well well well
Never forget that we can each learn from each other in just about all cases. I was not so silly as to say all engineers are stuffed shirts only that it was a possibility LOL. I don't even think I called you a stuffed shirt.
You never answered my question about parallel current carrying conductors and the length concerns.:thumbsup:
/ Ground Clamp Differences #37
Please tell me the context here. Are we talking a parallel transmission line here as in RF energy transmission? Such as 450 ohm open wire line? or something else? Telephone twisted pair longitudnal balance problems (60 hz pickup? Unequal currents due to resistance differences? I don't understand the question.
James K0UA
For what it's worth, I ordered the one on the left.
Ian
/ Ground Clamp Differences #40
on a welding lead I doubt it makes a (tangible) difference.. that is.. if we are talking a spare grund lead.. etc..
soundguy
James K0UA
2013 GMC Sierra 2500HD Ext. Cab Knapheide Service Truck (A68183)
2013 GMC Sierra...
FUEL TANK (A68842)
FUEL TANK (A68842)
2019 KENWORTH T680 (A67714)
2019 KENWORTH T680...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
2015 SILVERADO 5TH WHEEL (A67714)
2015 SILVERADO 5TH...
2019 CATERPILLAR 289D SKID STEER (A65056)
2019 CATERPILLAR...
