Ground Clamp Differences
/ Ground Clamp Differences #61
I have the one on the left on my stick welder and had a sheetmetal stamped clamp on my mig but just put a magnet ground on it and I really like it!! :D :thumbsup:
/ Ground Clamp Differences #62
Technically speaking don't the electrons flow from negative to positive and the holes moves from positive to negative ?
/ Ground Clamp Differences #63
yep.. electron current flow.. negative to positive.
conventional current. is just.. probably because ben franklin had it wrong and that's what people got used to.. positive to negative.. just add in the hole current theory you mentioned and it all kinda works.. :)
soundguy
/ Ground Clamp Differences #65
we have a 'white' truck at work that uses positive ground.
I have seen other heavy trucks of that era that even use isolated ground alternators.
soundguy
/ Ground Clamp Differences #66
Didn't the old Ford 6 volt tractors have positive ground ?
JB
/ Ground Clamp Differences #67
In telephony all Central Offices and PBX equipment is positive ground. We always refer to battery voltage as -48 volts. If you hook anything up with a negative ground, you are in for a big surprise:D
James K0UA
/ Ground Clamp Differences #68
JB
from the 1939 9n thru the 1964 2000/4000 gas models, fords were 6v positive ground.
in 59, diesel 4 cyl models came out and were 12v negative ground.
in 65+ with the 3 cyl's etc, they went all 12v negative ground.
some time in the 70's alternators replaced generators. i believe the 7000, got them first out of the 000 series, then by the x600 series it was alternators as standard.. etc.
soundguy
/ Ground Clamp Differences #69
A lot of old cars were also positive ground.
I had a 1936 Chevy that had positive ground with the 6volt battery under the floorboard.
/ Ground Clamp Differences #70
look at the volkswagon bugs..
soundguy
/ Ground Clamp Differences #71
I never really new the amount of systems that had a positive ground thanks for educating me everyone.
2022 INTERNATIONAL LT625 DAYCAB (A67714)
2022 INTERNATIONAL...
AIR GREASE PUMP W/STAND AND GENERATOR (A67714)
AIR GREASE PUMP...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
2024 CATERPILLAR 255 SKID STEER (A65056)
2024 CATERPILLAR...
Hyundai GP Bucket (A68134)
Hyundai GP Bucket...
PORTA POTTY (A67714)
