Post hole digger to Quick Hitch?
/ Post hole digger to Quick Hitch? #1
SSdoxie
Elite Member
Cumberland Plateau, TN
Bobcat CT225
Has anyone out there modified the boom on a Post hole digger to hook up to a 3 point quick hitch. I have all my attachments set up no to use off the QH except have to remove it for the PHD. If anyone has done it and has pics would be greatly appreciated.
/ Post hole digger to Quick Hitch? #2
Take a closer look at the geometry of the post hole digger. When attached to the quick hitch, you would have very limited working lift range. It would be easy to hook up and would look nice on there, but the functionality would suffer.
I think I can overcome the geometry with hydrualic top link, but I hit my first road block today. The A frame won't fit the Quick Attach, needs to be 1/2" wider on each side or 1 1/2" narrower.
/ Post hole digger to Quick Hitch? #4
Please post pictures of your modification; but I agree with Xskier concerning the geometry being all wrong.
/ Post hole digger to Quick Hitch? #5
I was thinking it would work if you took the top link off the tractor and took the A-frame off the PHD then you use the QH as the A-Frame for the PHD.
/ Post hole digger to Quick Hitch? #6
I tryed that a few years ago the geometry changed to much from up to down position.
I decided to bring this thread back to life now that I've had a couple days to get started on the Post Hole digger mount to QH mode. For all those that advised me of the geometry problem, Thank You. It will not work without using Hydraulic Top Link. On mine I would loose about 18" of travel without moving the top link.
First came the top link, I did this a few months ago. I modified a short grapple cylinder that I had laying around, used a rod eye end from an extra top link cut it to link and weld to base of the cylinder to same length as original top link.
Then the PHD: Relocted the lower lift pins to clear the lock taps on QH, moved them forward and slightly down.
Cut the PHD tube off same length as top link fully retracted. Then notched out bottom of the tube for QH hook to slide in.
The bar stock added on top is (3) 1/4" pieces to match width of the hook. They help pull the digger up tight and reduce side movement of the gear box when under torque.
To mount it: Drop the lift pins in lower hooks, raise end of PHD boom to slide pin through the hook, the raise little more and slide smaller hitch pin in.
Getting alot of pics here so will start another reply showing the movement.
1st pic is with 3pt down and top link retracted, end of boom 22" off ground.
2nd is with top link extended part way, boom hits the ground.
3rd & 4th pics are at fully raised top link retracted = 6'. Gear box with auger are 4'8" so I should have plenty of height.
If weather holds tomorrow I will get neighbor to help hang gear box and auger back on, stress test my welding and maybe shoot a little video.
/ Post hole digger to Quick Hitch? #9
Good luck SSdoxie... Let us know the out come
/ Post hole digger to Quick Hitch? #10
Well have you used it? Did it work good?
/ Post hole digger to Quick Hitch? #11
Still wondering how the PHD turned out...looked like a great idea!
/ Post hole digger to Quick Hitch? #13
You may want to try sending him a message, he may not be subscribed to this thread anymore.
Sorry for not updateing this sooner, I wanted to make a video of it but that hasn't worked out due to no one to help. It works quite well, but I do want to fine tune my top hook connection to make it a little easier to hook up. As it is, it is still faster to hook up than taking the QH off. Digging is great. I great positioned where I wan to drill, extend the hydraulic top link until auger hits the ground, then drill while lower the the 3pt. Move the auger up & down only with the 3pt to clean the hole, then raise 3pt completly then retract top link to lift all the way up.
Two advantages I found are:
1. PHD has more travel using 2 functions. It raises higher and will dig deeper when needed.
2. With it mounted to the QH, the arc of the gear box/auger when digging is less so very little movement forward after the auger starts to dig is required to keep the hole straight.
/ Post hole digger to Quick Hitch? #15
Thanks for the update SSdoxie I cant wait to see the video when you get one! I would like to see pics though!
GENIE AWP-36S MAN LIFT (A63569)
GENIE AWP-36S MAN...
2022 John Deere Z720E Zero Turn (A63116)
2022 John Deere...
2004 John Deere 4720 (A60462)
2004 John Deere...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
