Post hole digger to Quick Hitch?
   / Post hole digger to Quick Hitch? #11
1st pic is with 3pt down and top link retracted, end of boom 22" off ground.
2nd is with top link extended part way, boom hits the ground.
3rd & 4th pics are at fully raised top link retracted = 6'. Gear box with auger are 4'8" so I should have plenty of height.
If weather holds tomorrow I will get neighbor to help hang gear box and auger back on, stress test my welding and maybe shoot a little video.
Still wondering how the PHD turned out...looked like a great idea!
   / Post hole digger to Quick Hitch? #13
You may want to try sending him a message, he may not be subscribed to this thread anymore.
Sorry for not updateing this sooner, I wanted to make a video of it but that hasn't worked out due to no one to help. It works quite well, but I do want to fine tune my top hook connection to make it a little easier to hook up. As it is, it is still faster to hook up than taking the QH off. Digging is great. I great positioned where I wan to drill, extend the hydraulic top link until auger hits the ground, then drill while lower the the 3pt. Move the auger up & down only with the 3pt to clean the hole, then raise 3pt completly then retract top link to lift all the way up.
Two advantages I found are:
1. PHD has more travel using 2 functions. It raises higher and will dig deeper when needed.
2. With it mounted to the QH, the arc of the gear box/auger when digging is less so very little movement forward after the auger starts to dig is required to keep the hole straight.
   / Post hole digger to Quick Hitch? #15
Thanks for the update SSdoxie I cant wait to see the video when you get one! I would like to see pics though!
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2020 CATERPILLAR 306 CR EXCAVATOR (A52709)
2020 CATERPILLAR...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
HUSQVARNA RIDING MOWER (A52708)
HUSQVARNA RIDING...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
