Is Ventrac tough enough?
/ Is Ventrac tough enough? #41
OK, that hill looks just like one of my smaller ones. You are lucky you have a lake at the bottom, mine just gets steeper. I bet the kids love to toboggan on that bad boy. Looks like a fun ride.
Can you go sideways with the Ventrac on that btw?
/ Is Ventrac tough enough? #42
Sideways is actually a bit easier. Articulated machines don't turn around as easy as a zero turn, so that is why I usually mow it long ways. It takes all 31 horses of the VT to push that 84" mower up the hill, cutting long grass. The PT1460 w/ wide tires and the 90" mower can get up the hill (barely), but the tires tend to slip, and they rip the lawn up pretty bad.
Before I had the VT, I tried to mow it with my John Deere zero turn. Talk about a toboggan ride... lol
/ Is Ventrac tough enough? #43
Build a little ski lift or drive people up with the VT and you got yourself a great hill for sledding, skiing, snowboarding and tubing :thumbsup: Beautiful home btw
Oh even better idea! Build the snow up to that 'dinosaur egg' as MossRoad put it and make a ramp :laughing:
/ Is Ventrac tough enough? #44
Nice mowing AB! First time of the year? That is some impressive striping :thumbsup:
Thanks!!!
Here is a view of the other side of the pond, from the porch. This side was the second mow of the year, as the grass is much more established here. The Ventrac does nice striping, as it has a full width steel roller on the back of the mower. This was mowed on Saturday, and the striping still looks good. Bad thing with the striping is that you have to mow back and forth, or else it looks like crap. Takes a little longer, as you have to turn around after each pass. No Zamboni patterns....
/ Is Ventrac tough enough? #51
Those ventracs look like nice machines. (I would love one but I have no use for one, and since I am 14 I cant afford it):(
/ Is Ventrac tough enough? #53
Okay, I just have to ask: What is it with the striping that gets everyone excited (and I see that lots of people do)? I actually prefer seeing just a nice expanse of grass without it looking like someone just mowed it.
Ken
/ Is Ventrac tough enough? #54
Ken
I hear you. I said before that the striping actually adds time to the job, because you have to do it carefully or else it looks bad. It only lasts for a few days. The remarkable thing about the the VT contour mower is not the striping, but rather the way it can handle difficult terrain without scalping or leaving high spots.
/ Is Ventrac tough enough? #55
Ken
A striped lawn is beautiful in the right setting. So is an un-mowed field. Both have their place.
We had an old Simplicity lawn mower with full width rollers on the back that left a beautiful pattern on the lawn. I would mow it a different direction every time and sometimes would start in the center and work my way out in circles, ovals, squares or rectangles. The spiral out from the center was my favorite and got the most compliments.
Now, I do not usually have the time to do those intricate patterns and the PT does not do them well. But once in a while I'll tow our Brinley lawn sweeper behind me to get a nice striped effect. :thumbsup:
/ Is Ventrac tough enough? #57
/ Is Ventrac tough enough? #58
The Steiner costs less will not have as much HP but will mow, blow, scoop. check it out at Steiner Tractors and Attachments
I own both, the Steiner and the Ventrac. The Steiner isnt worth a pimple on a Ventracs butt. I bought both machines new and have to say the Steiner was the worse purchase I ever made.
/ Is Ventrac tough enough? #59
I like their ad
"Quick hitch. Change attachments in minutes" :laughing:
Power-Trac
Change attachments in 15 seconds!
http://mossroad.com/PT425Videos/PT425_15S01.WMV
The power trac attachment plate system is the easiest and quickest as long as your attachment does not require hydraulic power via the quick disconnect hoses-- then you have to turn off the tractor and dismount... I have found the belt driven PTO on the Ventrac much easier to deal with. However, some of the Ventrac attachments also use hydraulic connections as well. So for most attachments that I use I think Ventrac has a slight edge. I chose to buy a power trac for other reasons including the cost factor.
/ Is Ventrac tough enough? #60
Why do you say that? What is it about the Steiner you don't like? Is it Horsepower, size, the operations?
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
Tailgate Mulcher Portable Hay Blower (A65579)
Tailgate Mulcher...
2004 Peterbilt (A62679)
2004 Peterbilt...
Landhonor ATS-ME18 Mini Excavator (A66285)
Landhonor ATS-ME18...
New/Unused Landhonor 12V Diesel Pump (A65583)
New/Unused...
