MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,039
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
The power trac attachment plate system is the easiest and quickest as long as your attachment does not require hydraulic power via the quick disconnect hoses-- then you have to turn off the tractor and dismount... I have found the belt driven PTO on the Ventrac much easier to deal with. However, some of the Ventrac attachments also use hydraulic connections as well. So for most attachments that I use I think Ventrac has a slight edge. I chose to buy a power trac for other reasons including the cost factor.
With me not being familiar with the Ventracs, I cannot see how a belt hook up could be easier than a hydraulic hose hookup. It takes me about 15 seconds to get off the PT and connect/disconnect hydraulic hoses. I have had belt powered implements in garden tractors and it required me getting on the ground and inevitably snapping my fingers between a belt and pulley. :laughing:
