Blade Speed
/ Blade Speed #1
glc24
Southwestern, Pa.
Hey guys
Does anyone know what the blade tip speed is on the 2520 with the 62D deck?
Engine rpm is 2500.
Thanks
Greg
/ Blade Speed #2
I think all of the ratios for the gear box and belt drive are nearly 1:1, so the blade shaft speed should be the same as the PTO. If we assume that is the case, then it would be:
blade length x pi x RPM
21.5 x 3.14 x 2100 / 12 = 11,814 feet per minute or about 134 MPH
Someone correct me if I'm wrong.
/ Blade Speed #3
I was thinking the tip speed was somewhere around 15,000 or 16,000. Maybe I am way off.
/ Blade Speed #4
My 72"mmm has a tip speed of 15,300. Check the specification section of the owners manual that is where I found mine. Let us know.
/ Blade Speed
Hey PCABE5
This is all that is listed for specs on my deck.
Specifications
Really nice that yours had more info.:thumbsup:
I guess I could "assume" that the 62D is somewhere in that RPM range.
I was just curious,because when you bring the deck up to speed,you can tell they (blades) are really hummin' under there.:)
Greg
/ Blade Speed #6
I approached the question and got the answer using a optical tack. Not just to answer the blade speed question. I have used the tach for many tasks. I found the tractor engine speed to be almost 200 rpms over spec. measured the engine speed that gives 540 at the PTO, calculated the overall engine to PTO ratio, calculated the brush hog speed gear box ratio and tip speed. The optical tach is amazingly accurate, just point it at a florescent light and it reads 3,600 run .
60 cycles/ sec x 60 sec/min = 3,600 rpm
http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
/ Blade Speed #7
Digital Photo Sensor Tachometer
Don't keep us in suspence, what was the answer?
3ft. 5-Point Metal Star (A61574)
3ft. 5-Point Metal...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
2018 Utility FS2CHA 48ft. 36 Ton T/A Flatbed Trailer (A61573)
2018 Utility...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
