Blade Speed
/ Blade Speed #1
glc24
Southwestern, Pa.
Hey guys
Does anyone know what the blade tip speed is on the 2520 with the 62D deck?
Engine rpm is 2500.
Thanks
Greg
/ Blade Speed #2
I think all of the ratios for the gear box and belt drive are nearly 1:1, so the blade shaft speed should be the same as the PTO. If we assume that is the case, then it would be:
blade length x pi x RPM
21.5 x 3.14 x 2100 / 12 = 11,814 feet per minute or about 134 MPH
Someone correct me if I'm wrong.
/ Blade Speed #3
I was thinking the tip speed was somewhere around 15,000 or 16,000. Maybe I am way off.
/ Blade Speed #4
My 72"mmm has a tip speed of 15,300. Check the specification section of the owners manual that is where I found mine. Let us know.
/ Blade Speed
Hey PCABE5
This is all that is listed for specs on my deck.
Specifications
Really nice that yours had more info.:thumbsup:
I guess I could "assume" that the 62D is somewhere in that RPM range.
I was just curious,because when you bring the deck up to speed,you can tell they (blades) are really hummin' under there.:)
Greg
/ Blade Speed #6
I approached the question and got the answer using a optical tack. Not just to answer the blade speed question. I have used the tach for many tasks. I found the tractor engine speed to be almost 200 rpms over spec. measured the engine speed that gives 540 at the PTO, calculated the overall engine to PTO ratio, calculated the brush hog speed gear box ratio and tip speed. The optical tach is amazingly accurate, just point it at a florescent light and it reads 3,600 run .
60 cycles/ sec x 60 sec/min = 3,600 rpm
http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
/ Blade Speed #7
Digital Photo Sensor Tachometer
Don't keep us in suspence, what was the answer?
New - Front mount rototiller
New - Front mount...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
BOBCAT CT4058 TRACTOR (A62130)
BOBCAT CT4058...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2017 Ford F-150 Pickup Truck (A61573)
2017 Ford F-150...
2012 WESTERNSTAR 4900FA (INOPERABLE) (A63569)
2012 WESTERNSTAR...
