low RPM
/ low RPM #1
nwltruck
north west Iowa
'07 John Deere 3320
Just wondering .......... I have heard that it is harder on the diesel engines to run them under load at a low RPM.(work not requiring 540 PTO) Is this just turboed engines or all diesels. What damage would I be doing to my CUT.
/ low RPM #2
I have a JD 4100 diesel and will often mow, if the grass isn't too heavy, as well as use the FEL at 1500 to 2000 rpm. Never noted any issues. I will run at PTO speed if the going is tough and I think I need max power.
I await the experts weighing in.
/ low RPM #3
It's bad if that is all you do, but ideally you should pick the rpm to suit the task, you want the engine under a bit of load, but not straining to keep up. There is no point running at full rpm if you don't need it, all your doing is wasting fuel. Same goes for PTO, just because it can run at 540rpm doesn't mean it has to, often tasks like mowing, slashing (bushhogging for those in the US) spraying don't need more than about 480-500rpm but once again this comes down to what your trying to achieve.
/ low RPM #4
when i use my tractor i run it 1500 rpms just driving.when im working the tractor i run at 1800 or 2000 rpms or more depending on what im doing.to run at 540 you need 2700 rpms.
/ low RPM #5
According to the folks at my Kubota dealer, diesel engines, particularly the smaller ones, AND including the hydraulic pumping system, are much happier
running at higher RPM than at lower. The faster the engine/pump is operating, within red line of course, the less strain on the systems.
Fuel consumption will be a bit more, but which is less expensive, fuel or repairs? Same reason a car/truck engine is happier if one downshifts when going up steep grades.
Me, I keep the RPM up when using the implements..
Regards,
Dennis (WA)
/ low RPM
I have have been mowing at 2000,and doing loader work at 1100 to 1500. Just seems to me that the little thing is really screaming at 2700 to get 540 PTO when I snow blow. Thanks for the info and opinion. Sounds like I'm doing what I'm supposed to.
/ low RPM #7
it is not good to run it at low rpms in the long run because it will start slobbering oil and smoking
/ low RPM #8
lugging is what you eed to be concerned about. don't lug them.. otherwise running a hair low on rpm isn't usualy a huge deal unless you are using an implement that specifically needs a set rpm for power generation.. or some pump flow that is being utilized.. or a broadcast spreader that relies on rpm for spread width.. etc.
soundguy
/ low RPM #9
We ran our farm tractors for hours at a time cultivating when the crops are small and you dont want to go too fast. As long as the engine is not lugging down, low rpm wont hurt a thing. There is no difference in locking your cruise control in on your diesel truck and running for miles and miles or any other engine. Cars are built to down shift when needing more power and if you watch you loading of the engine, running at around 1500 RPM or higher is not going to hurt your tractor. Anything less than that might cause a little carbon build up in the exhaust that will blow out as soon as you rev it up.
/ low RPM #10
Like many, I run my engine appropriate to the task.
I usually don't go below 1500. I usually run my PTO equipment at or close to 540, but for years ran our 60's model Case and cutter at what "felt right". It is still running strong and never has had any repairs.
I am no different than many in that maybe I tend to over think some of this stuff. When I was younger and did this for a living so to speak, I operated more by feel than anything else.
I do accept there are parameters beyond which we should not go, but they may be broader than some of us think.
/ low RPM #11
I am new to my BX23 but not to diesel engines. My FIL who was a potato farmer and owned lots of tractors and trucks taught me never to lug a diesel engine. I think that is why truckers use so many gears. As an indicator if I am lugging the engine or not I increase the throttle a little, if the rpm picks up the engine wasn't lugging, if the rpm doesn't pick up then the engine was lugging and I should downshift, mow less wide, raise the mower or do something else to lessen the strain on the tractor. At the other end of the scale, it is bad to overspeed an engine of any kind. When I was training to be a flight mechanic on C-54s (DC4s) in the Navy I learned about the dangers of a propeller going into flat pitch and overspeeding an engine. One of the things that can happen to an engine that has some time on it is that a ridge develops in the cylinder at the top of the piston travel. In an engine that is overspeeding the top rings hit that ridge and they can break. I told the guy that was training me that at least in my little Aeronica Chief with a 65 hp engine and fixed pitch prop I wouldn't have to worry about overspeeding the engine. He pointed out to me that if I put the plane in a dive with the throttle wide open the engine would almost certainly overspeed. Several years ago we loaned our 5040 Allis to a couple of guys to pull a little planter that needed to go slow but required no power to pull it. I happened on them in the field and they were running the engine wide open in 1st gear. I told them not to do it and they told me diesel engines were made to run wide open. That may be true but not when they have no load on them. It cost me $1,700 to overhaul the engine after their little stunt. The one place that I see that it would be easy to overspeed my 5040 is when I am on the road going down a long hill, I back the throttle off some. I am careful not to lug or overspeed the engine and it has 3600 hrs on it since that overhaul and is still running strong and uses no oil. I am not sure about overspeeding the little Kubota engine with the HST and hydraulic pump in my BX23. Maybe those two items give enough resistance to prevent an overspeed. I just don't know at this time.
/ low RPM #12
Low RPM can result in "pounding" the main bearings. Remember, these are shell bearings that do not rotate and depend on a very thin film of oil. Low RPM also results in lower oil pressure.
"Pounding" would be equivalent to hammering on one spot continously...picture that.
On a shell bearing, it can ultimately result in wear at one point of the bearing...that turns into low oil pressure and premature bearing failure or scoring of a crank journal.
Even when I'm idling the tractor with no load, I keep the RPM at 1500.
Of course, how low is "Low RPM"?
Depends on the engine. Shipboard diesel turn very slow (300 RPM) but also have very thick bearings and a (relatively) easy method of replacing them. Some tractor diesels max out at 2000RPM.
But for our CUTs with engine displacements of 100 ci and maximum RPM limits at around 3000, I suggest keeping a no load idle at 1200-1500,
/ low RPM #13
FWIW, my Kubota manual specifies running the motor at PTO speed for everything, from sitting and warming up after a cold start, to all forms of operation.
I do let the machine warm up at close to idle, but do push up the RPMs to maybe 25% into the operating range. I do run wide open (at or just past PTO) when operating my backhoe or snowblower, but usually run about 80% of PTO speed for driving around or most other operations.
JayC
/ low RPM #14
....... I do run wide open (at or just past PTO) when operating my backhoe or snowblower, but usually run about 80% of PTO speed for driving around or most other operations.
JayC
I stopped by my dealer and inquired as to why my backhoe operations seemed
to be on the jerky lurchy side. He suggested that keeping the RPM up would help smooth things out by providing more available power and therefore less control travel to achieve same result. Or something along those lines.
More power would also help overcome any stiction issues with a particular system.
Dennis
/ low RPM #15
more power? HMM... more flow.. but pressure it develops should be the same at idle vs throttle... at least if it is a positive displacement pump..
soundguy
/ low RPM #16
JayC
My MF owners manual states the same thing. States to run the engine at full throttle once warmed up.
/ low RPM #17
Does RPM matter with HST tractors? I was under the impression with HST you were supposed to run tractor at certain RPM and control speed with trans.
/ low RPM #18
Yes RPM's matter on HST tractors....for all the reasons stated above.Get it up to operateing range.I don't run mine below 1500,when working 2,000+.Pto speeds at 2400-2500.
/ low RPM #19
I've seen people operate equipment that are running to low of a RPM. I think people think they are going to "save" the motor by spinnin it slower. My in laws were running a tractor and doing loader work at very low RPM's. It was lugging the engine so bad I was about ready to say something. On the other hand, for a lot of tasks, why run the thing wide open if you can throttle back a little bit. I own a Kubota BX and the only thing I do at full throttle is mow. If I run full throttle for loader work, it seems to jerky. There seems to be a sweet spot for most tractors to run at, the trick is to learn what that RPM is and use it. For my BX it seems to be around 2500 rpms for most things except mowing, which I run flat out just to get the blade speed as high as possible.
I don't think it is possible to overspeed the engine on my BX, it has a govenor that seems to work well.
/ low RPM #20
It might not be possible to overspeed it with the throttle, but a gear driven machine can be mechanically over revved by going too fast down a hill.
Lot of 4 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Lot of 4...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2015 International ProStar T/A Day Cab Truck Tractor (A61573)
2015 International...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2004 John Deere 4720 (A60462)
2004 John Deere...
