RoyJackson
Rest in Peace
- Joined
- Nov 17, 2001
- Messages
- 24,646
- Location
- Bethel, Vermont
- Tractor
- John Deere 4052R Cab,, Deere 855D UTV, Z920A Zero Turn Mower and assorted implements
The only problem is that is much slower that just driving forward across the slope. Tightening up the three point is a good point - it was tight when I started, but seems to loosen up after a few hours of mowing.
On a slope, slower is just what you want...unless the grass is wet...then it's "WAIT".
Tightening the anti-sway links is probably a good idea, but they shouldn't be loosening. I suggest, after tightening with the cutter on the ground, you lift it and recheck the sway (retightened or adjust as required).
Sometimes what feels tight when the implement is stationary on the ground turns out to be not so tight when in operation.
