Automotive question
/ Automotive question #1
gregsons
new york
ford 3500 / dultz allis/ IH 434
This is most likely not the place to ask but people on this forum have help me out on many differant issues.
Im trying to get my 84 Monte carlo ready to sell. I have only driven it about 100 miles in the last 2 years. But now its making a ticking sound coming from the drivers side of the motor. Seems like half way back near the head not the bottom of the engine. If i give it gas the ticking speeds up. Im thinking lifters.
Questions: From what i have give what could it be? If it is lifters whats in it to replace them? take that head off? Any info would be welcomed.
Thanks
/ Automotive question #2
Thanks
Sounds like a collapsed lifter to me. Driving it as little as you do is aggrevating this. I would warm it up, change the oil and put a couple hundred easy miles on it see if the lifter pumps back up...Sometimes they do.
/ Automotive question #3
To be honest it is what it is. I would pull the valve cover and take a look and maybe change the oil to the heaviest weight allowed by the book. At the end of the day its a nearly 30 year old car. It can not be worth much so sell it as is. You could not fix it and break even.
Chris
/ Automotive question #5
Are you sure its not just a leaky exhaust manifold/header ?...............just a thought.
/ Automotive question #6
Try a can of Marvel Mystery Oil...might free up that lifter.
/ Automotive question #7
Oil change and Marvel Mystery oil, both good suggestions.
My 92 Ranger did this after being parked for a few months. Oil change with syth, warm it up, no more ticks.
Thanks for all the suggestions Ill change the oil. Even thought i dont drive it much i still change the oil every year in the spring when she come out of the garage. Im also going to check the adjustment of the rockers.
Nope not a exhaust leak that was my first thought too.
I sure hope it dont cost more then the value of the car to fix. I have alot of $$ into this girl
/ Automotive question #9
How about some pictures?...I like that year Monte.
/ Automotive question #10
I don't think that the rockers are adjustable? Been a long time since I've been in one. I wouldn't take anything apart yet. Put some stuff in the oil for sticky lifters and see if that don't clear it up first.
/ Automotive question #11
I'm guessing it's a 305. If it is the rockers can be adjusted somewhat, but not much.
/ Automotive question #12
Maybe, but I'm thinking it's solid lifters you adjust not hydraulic lifters which are normally self adjusting. Like I said, been a long time since I've been in one.
/ Automotive question #13
solid lifters? possible, but if you had them, i'd think you would remember that for certain. solid lifters are generally only used when you have something that turns a fairly high rpm, 6000+ rpm, give or take. at that high of an rpm, the hydraulic lifters can't keep up as well. most all vehicles use hydraulic lifters because they are less stressful on the rest of the valve train because of the cushion provided. they also handle slight out-of-adjustment conditions better due to this, but it doesn't mean they don't have to be adjusted.
Yes its a 305 ci engine it had hyd lifters im going to check to make sure they (rocker) are tight and change the fluid and baby it around town. If that dont work ill have to get into it a little more, take the head off.
Is it true that these can go bad with lack of use?
Ill get pictures up this weekend thank again for the help.
/ Automotive question #15
rockers are adjustable,sometimes adding atf will help quiet lifters
/ Automotive question #16
I was going to suggest this also but thought I would take a whipping here for saying it. Maybe put a 1/2 qt in and drive it around a few miles then change the oil.
At the end of the day its a old car, not perfect. If you go fixing everything you will never make any money. I can not imagine a 84 anything is worth much.
Chris
/ Automotive question #17
Chris
If it's an 84 Monte Carlo SS it could be worth something...They still bring a nice buck around here if they're nice.
Few if any V8's in that era had solid lifters, most all domestics ran hydro's. If someone built the motor, all bets are off.
Not sure I'd personally go the ATF route. I'd do what I mentioned prior. If the tick is slight, the rocker can be snugged a bit...Have to be careful doing that though. If the lifter eventually releases, you could have a slightly open valve. A light tweak to quiet the rocker shouldn't be an issue, there's probably enough play in the system to handle it. I've done this in the past.
/ Automotive question #18
i think i'd change the oil and put in a can of seafoam AND a half quart of MMO.. run the bajeebers out of it and see what it does.
I've had valve/train noise from a setting engine thet went away with new oil and solvent based addatives.. then switch to a good oil on it's next change..e tc.. er.. that will be the new owners job then to keep it serviced regularly and not let it set and sludge up.
soundguy
/ Automotive question #19
I don't remember if that one has roller lifter or tappets. If tappets, then make sure you use oil that has the zinc/phosphorus needed to help those survive. I had a cam go flat because I changed the oil on a lightly used 73 chevy. It had double valve springs and high lift cam. Most of the new oils do not have enough of the zinc/phosphorus additives for the old engines. You can buy several brands of oil, specific for the older engines or you can buy the additives and add it to normal modern oil.
/ Automotive question #20
sounds like a good candidate for a quality C rated 15w40
soundguy
2007 Volvo VNL Truck Tractor (A61307)
2007 Volvo VNL...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Giyi GY-CYHC Mini Quick Attach Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
(8) 295/75R22.5 Tires (A60463)
(8) 295/75R22.5...
