3pt blower
/ 3pt blower #1
Jay4200
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I want a 3pt blower to blast the leaves and sticks such off my driveway pre-winter. They are commercially available, but unfortunately cost about $4k. They look awfully simple from what I can tell. I think the innards of the things are a big flat-bladed fan (3ft diameter) - like a snowblower 2nd stage fan on steroids - mounted in a drum. The fan is belt drive off of the PTO with a 2-3x speed increase, so the mechanics should be fairly simple. I would think I could fab one for a tenth of the price of a commercial unit.
However, I wonder how critical balance on a big spinning wheel like that would be. Do you think an unbalanced 1500 RPM wheel that is 3' in diameter would rip itself apart? Any other thoughts?
JayC
/ 3pt blower #2
Give it a shot, as I think you have a good idea.
Do you have a fan in mind, or thinking of fabbing that as well?
/ 3pt blower
I'd have to fab that.
My other idea is to use 4 furnace blowers that are all ducted together. That would be trickier, since they would all have to belt driven from a common shaft, then be mounted such that their belts could all be independently adjusted. I was running with that idea until I saw what the fan on the Agrimetal blower looked like. Seems like is would be relatively simple to put something similar together:
JayC
/ 3pt blower #4
As far as balance goes, I'd tend to think the greater the mass and the larger the diameter, the more critical the balance, as there is much more force to tear things apart. (Ever see an out of balance ceiling fan?:eek:) That being said, it shouldn't bee too hard to balance a fan in the first place, as it will probably be fairly light. Even hanging it from the center of the hub and doing a static balance would get you close.
Good luck on your build!
Joe
/ 3pt blower #5
There are some other posts here about one of those, also some have used old sileage blowers converted to leaf/yard blowers that work quite well.
/ 3pt blower #6
Check out the farms, see if amy of the local farmers has an old silage chopper or silo blower that you could rape for a blower. Both of these items have a nice heavy blower on them, as well as gearboxes etc.
/ 3pt blower #7
I would think balance would matter at that size & RPM...BUT, how about designing the fan so you could mount it to a tire balancer and balance it that way? What I've got running thru my head right now would be to use something like the front hub off a front wheel drive car (not saying thats what I'd use, but I use that example to illustrate what I have pictured in my head)...Using a hub like that you could bolt your fan on..that fan could be mounted on a wheel balancer like a rim is...after a couple spin balances, drill holes here to lighten, weld a nut here, etc... and you could probably get it pretty balanced.
/ 3pt blower #8
I have a Woods leaf vacuum and a Toro Billy Goat style vacuum. The Goat converts to a blower from sucking if needed. The fan and shroud are identical for the two units. Why not get the blower housing and fan and rig up the shaft on some pillow blocks and run it at 4cycle motor speed (3000+ rpm). Or better yet, these bolt straight onto a small engine block. Forget the pto drive. Make a walker unit. Using a tractor to do this is way overkill.
But then, if you still think you need to mechanize it, buy the parts you need from Agrimetal and paint it up.
John Deere F935 diesel front mower w/ Agrimetal blower | eBay
/ 3pt blower #9
JayC
I think you need a old silage blower. Remove everything but the fan and it should be easily 3 pt mounted and direct drive should give you plenty of velocity.
/ 3pt blower #10
Hi, Done this using blower from industrial oil heater (Furnace I suppose to those in US of A)
Simple frame and pulley ratio to increase pto to about 1200 rpm - only pulleys to hand at time.
About 4 hours work in it including putting keyway in shaft.
Total cost about $30
It works very well and is easy to create large piles of leaves and beech husks
I have a couple of pictures somewhere if any one interested I can post them up.
/ 3pt blower #11
Pls post the pics, Densleigh
We like pics.
/ 3pt blower #12
When in doubt about posting photos... **Always do it** :laughing:
/ 3pt blower #13
If you check out one of the fan manufactures sites , like Delhi you would be able to see fan curves charts and Hp requirements.
A reverse incline blade will give you the best bang for the 540 rpm of a PTO.
Balancing is an issue if you want to keep the fan operational, and you must think of the unbalanced pressure on the PTO shaft. Not a big deal to balance. If you made the wheel and took it to a Balancing shop (there are places that just balance things you need to search the web in your area for the closest one) It should not cost a lot of dollars. :thumbsup:
/ 3pt blower #14
I used to own a 3pt blower and I must say they can be powerful. I know a dealer near me (and you) that has a used one for sale. It is gear driven and suitable for 20 or more HP. They do take a lot of HP. Contact Tony at Toreku Tractor in Harvard, MA 978-772-6619. He doesn't give anything away though he has had this one for at least a couple of years. I'd offer him $500. This blower will be a lot more durable than a homemade rig.
Good luck.
Will 978-857-8281
/ 3pt blower #15
Yes we need some pics asap. I want to build one of these while im off work.
/ 3pt blower #16
Check out local auction sales that sell commercial equipment. I've bought a few of these for resale over the years and most go for $100 or less used. Golf courses use them and sell them quite often. I have 2 brand new units sitting on my fenceline right now that I bought for $150, mount to front of lawn tractors and are belt driven. I might even have a couple 3 pth ones too. I have an almost new Steiner one too that I use for pavement blowing. They take more hp that you might realize so don't be building it too big.
/ 3pt blower #17
Dont know what auctions your going too but i have never seen one at an auction. Post some pics for us and maybe ill have to buy one from you lol:laughing:
/ 3pt blower #19
I am thinking broom I went to the city shop a while back and got a well used broom plans are to put it on my loader (2305) and power it with a 11 hp gas engine I want to fab it up so I can use my pallet forks all I need is some time.
/ 3pt blower #20
Sorry 204 saskman, I sometimes forget I posted in threads. I'll try to get some pics tomorrow of the ones I have. Was at a sale last week and they had a few, cheap I think but never really paid much attention. I have a few pics on other sites of some stuff I have built, same user name if you wanna search. Lawnsite and arboristsite.
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
2013 BAD BOY AMBUSH RTV (A64280)
2013 BAD BOY...
2015 DODGE DURANGO RT SUV (A59912)
2015 DODGE DURANGO...
2020 John Deere 470G Hydraulic Excavator (A61572)
2020 John Deere...
2017 INTERNATIONAL PROSTAR + 122 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 INTERNATIONAL...
