A new use for a front end loader
/ A new use for a front end loader #1
allen in texas
Levelland, TX
Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
Spent this last weekend lowering the 2008 FXSTC. Had to get under it to remove the shocks and this made it a snap.
ps,
that's my brother. He might get mad at me for posting a pic of his nose bump protector. (belly) :)
/ A new use for a front end loader #2
The fel sure does come in handy sometimes. I drive my ztr's front wheels into the bucket, curl the bucket up a bit and lift the ztr up so I can maintain the deck and blades. I always block my bucket before getting under the mower also.
/ A new use for a front end loader #3
FEL has way saving on pinch fingers or skin off knuckles. ;)
/ A new use for a front end loader #4
ps,
Mr Allen;
If you raise the loader a little higher or curl the bucket a little further back, you will be surprised at how fast the chains unhook and the load crashes to the ground. I am not singling you out, but just using the picture as an example.
I think the bucket hooks should be 4" in from the ends of the bucket, and then the chains should be run over the cutting edge. No matter how much lift or curl the chains would always remain hooked, unless they slip off the end of the cutting edge. Not even in the dark with wind and rain and the operator in a hurry. Not that you would be changing shocks in the rain,:)
/ A new use for a front end loader #6
i dont use chain hooks.if i have to lift something with the loader i secure the chain to the hay forks an do the lifting.
/ A new use for a front end loader #8
ps,
I thought that was a "tool shed" he has been building w/ a liquid diet:laughing:!!
Mr Allen;
UH OH!
I've been pulled over by the safety police. :laughing:
That's ok. I've never dropped anything because of a chain coming unhooked, and I've lifted lots of stuff, but I guess it could happen.
I had the bucket rolled back the way it was because there is about 30 foot of grade 70 chain in the bucket and about 15 foot of some other grade chain and I didn't want it to come crashing down on the bike. My "short" chains were in my truck box and I didn't want to go get them.
/ A new use for a front end loader #11
There is an old thread on unusual uses of a FEL, all very interesting.
We just won't go into everything for which mine have been used, but picking up a motorcycle would not be one to cause me concern.
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
3PT TINE RAKE (A63291)
