Homemade toolbox examples
/ Homemade toolbox examples #1
DavidAubke
Southeast Ohio
Kubota BX2350
It's tough finding a spot to carry anything other than a beverage on a BX. I've seen some fine examples here of homemade toolboxes including this recent one.
I just added a small toolbox to my BX2350. This is an easy project that only requires a little very simple metal fabrication.
The box itself is this toolbox from Northern Tool.
It's held on by two U-bolts and some angle iron.
Carriage bolts and nylon lock nuts attach the box to the angle iron.
I cut a piece of sheet metal from Lowe's (not sure what gauge I used) to reinforce the bottom of the toolbox. Without this, I doubt the plastic box would be able to hang on by two carriage bolts. The toughest part of the project for me was squaring the bolt holes in the metal. I think I ended up grinding them most of the way with a Dremel then just pounding the carriage bolt in there to finish the job.
It's not rock-solid but maybe sturdier than it looks. I had doubts until I tightened everything up. It's been on for around 10 hours and I'm very happy with it.
I meant to point out that in the first picture, you can see that the 25CDA Tilt Meter fits well on the loader valve.
/ Homemade toolbox examples #3
Nice project. My only comment is to get rid of the sharp corners and put acorn nuts on the ends of the U bolts. I tend to leave a lot of skin on anything sharp.
/ Homemade toolbox examples #4
Now you have a place to keep some tools, spare pins and stuff. Your sheet metal bottom was a good idea. :thumbsup:
/ Homemade toolbox examples #5
That's very similar to mine: http://www.tractorbynet.com/forums/build-yourself/199286-b21-toolbox.html
But after only three or four weeks I could see the plastic wasn't going to hold up in the sun and weather in general as it had already begun to lose a lot of its color. Considering I carry a heavy chain in it as well as tools, I thought it wouldn't be too long before I ran over a bump and the whole thing would crack from brittleness.
I replaced it this weekend with a metal version which I will paint with some Kubota Orange II.
/ Homemade toolbox examples #6
Here is how I done mine. Its just the right size for me.
/ Homemade toolbox examples #7
Here's my attempt at a tool box. Made it out of 3/4" square tubing and some expanded metal. Drill and tapped the frame to secure it. Added a place for my 2 year old son to stand.
/ Homemade toolbox examples #8
Not to start an argument here but I fail to understand why some one would use a tilt meter?
Every tractors and situations are differents and if you're fine at 10* with an empty FEL down, what do that mean with a loaded FEL in a higher position?
Most roll over happen because one wheel either go up on a rock,etc or go down in a hole.
A tilt meter is completly wortless in "real" life and can give you a false sense of safety
/ Homemade toolbox examples #9
I would not be so fast to condem them. I have one. When I was a new operator it gave me useful feedback. It helped me get a feel for the tractor.
What you say though is true. Every situation is different. You cant say - OK, I'm good for 15*. That is not what it is ment for.
Now I use it to check my road contours while grading. It is hard to tell what angle you are at on a side cut when you are grading for drainage. I find the tilt meter useful as a rough guage.
/ Homemade toolbox examples #11
Hi Leejohn:
If I may inquire where did you get the step(if you have part # manufacture) or is it homemade. Find as getting older first step is getting harder esp with boots winter coat on!!
Thanx Pat R
This is perfect. I was hoping that by naming the thread this way others might add their projects. I remember a nice one made from pvc pipe (painted Kubota Orange) just strapped to the loader frame but can't find it right now.
I like using this board to find examples of others' homemade improvements but they're not always easy to find. I'm hoping that by using this name, the thread can be found easily by someone trying to figure out how to add a toolbox to their tractor.
It would be really cool to see other similar threads for things like ballast boxes, canopies, skid plates, loader forks, etc.
You're absolutely right that a tilt meter is not to be used to decide whether you're safe or not in any given situation. I have always used my clenchometer to make that judgment. The tilt meter is nice for keeping my butt calibrated.
I think that after prolonged use on slopes or uneven terrain, your internal gauge can get a little out of tolerance. The meter is nice to glance at every once in a while to confirm that reality matches your senses.
Also, it can be useful for grading.
/ Homemade toolbox examples #14
There are several old threads in the archives on this subject. Just use the search function.
There are hundreds of threads on those subjects in the archives. :) One can just browse by going back a page of threads at a time, or use the search function.
Just curious, as you mention things not always being easy to find. Have you had difficulties in getting the search function to work for you?
/ Homemade toolbox examples #16
here is mine
/ Homemade toolbox examples #17
I like it. I may have to copy that for mine
/ Homemade toolbox examples #18
Hi Leejohn:
Thanx Pat R
I made it. I use one 5/16th bolt to hold it on, could hold it on with a pin. I haven't tried the pin yet because I thought it might rattle. It has to come off when I put my deck on, but only takes a min. It is also adjustable in and out about 1 1/2", I use mine all the way out. Maybe I could make you one if you would like one. PM me.
/ Homemade toolbox examples #19
Pat I just looked at your profile and see you have a BX23. I'm not sure that would work for you. Would have to do more checking before I could make one.
Lee
/ Homemade toolbox examples #20
get yourself some J bolts and then adapter to go between the ends of the U clamps to J bolts. and you can hang chains from, or 5 gallon buckets of tools from.
though at quick look, i might encourage a little bit bigger U clamps. at least if it was me. i would most likely end up bending those U clamps, with what i fill 5 gallon buckets up at times.
Massey Ferguson 8200 Flex Grain Platform (A66285)
Massey Ferguson...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
New/Unused ATS Electric Jack (A65583)
New/Unused ATS...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
