Sprung a leak, can someone offer advice?
/ Sprung a leak, can someone offer advice? #11
Skip,
make sure the oring on the fitting doesn't crash on the threads on the fitting.....there is a right and wrong way to install these....best to take off and check to make sure and put a new oring on....
/ Sprung a leak, can someone offer advice? #12
Skip,
Yep, what he said! The lock nut should be completely covering the threads and only tightened to lock the fitting in place.
Had a customer return about an 1 1/2" fitting when I worked at a hydraulic shop that he installed with the nut all the way to the top and destroyed the o-ring washer.
He was wanting a new fitting for free and I had to explain to him that warranty doesn't cover stupid!
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2019 Felling Trailers 9 Ton 18ft T/A Flatbed Equipment Trailer (A59230)
2019 Felling...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
John Deere 5075E (A53317)
John Deere 5075E...
