Grease Gun and a Screwdriver
/ Grease Gun and a Screwdriver #1
kday64
Gold Member
South Eastern Connecticut
Kubota BX2360
Hi all,
I am curious if other folks have a hard time pulling thier grease guns off of zerk fittings. I have been using a flat head screw driver to help me get a little leverage to pop the grease gun off of the zerk fittings.
I am using a Lucas Hand pump grease gun with red and sticky #2 grease.
I know I don't want the grease gun fittings to be too loose but I dont remember having this problem on my father's old tractor.
~Kevin
/ Grease Gun and a Screwdriver #2
On the tip of your grease gun fitting you may notice a knurled area on the very tip. It is knurled so that you may twist it to loose it with your thumb and forefinger. If you twist it counterclockwise it should loosen and that will make the fit on the grease zerks very loose. if you tighten it, it will be very tight. I often loosen it to slip over the zerk very easily, then tighten it a little while on the zerk to stay on by itself, pump in the grease, and then loosen it to easily remove. If you cannot get it to twist to loosen, take a pair of pliers or 2 pair of pliers to hold both sections of the tip.
James K0UA
/ Grease Gun and a Screwdriver #3
James K0UA
Exactly what I was about to say. If you can't get the tip adjusted, go down to your local auto parts store and get a replacement tip for your grease gun that is easily adjusted.
/ Grease Gun and a Screwdriver #4
You can usually get them adjusted so they will stay on when pumping grease and pop off when pulled a little. Then you dont have to loosen tighten all the time. Takes a little to find the sweet spot.
/ Grease Gun and a Screwdriver #5
James K0UA
WOW!!!!!!!!!!!!
I learned something new today!!
Thank you, James!!
/ Grease Gun and a Screwdriver #6
WOW!!!!!!!!!!!!
Thank you, James!!
Me too. I had to go out to the garage to make sure my grease guns work that way.
How embarrasing--68 years old and I never figured that out! No one ever told me, so I wonder if any of them knew.
/ Grease Gun and a Screwdriver #7
I learned something new about grease guns about 60 years ago. Roll the tip to one side and it will nearly fall off. I've never had to adjust a gun tip and I've greased my share of zerks.
And I suspect the asian made junk is causing some problems too.
/ Grease Gun and a Screwdriver #8
We have a hard time getting it off the BH stabilizer zerks...I still have to try the adjustment mentioned above.
/ Grease Gun and a Screwdriver #9
WOW!!!!!!!!!!!!
Thank you, James!!
Glad to help out a little guys:) What the other fella said about finding the "sweet spot" can work too.. but sometimes not all zerks are the same size, so you have to adjust a little at times.
James K0UA
/ Grease Gun and a Screwdriver #10
To get at the zerks on the FEL main anchor pins (the ones at the top of the main frame) you have to stick the gun thru a hole in the standard. Once the pins are greased I just lift the FEL and it tilts the zerk in the gun until it pops off easy...(JD 4300)
I'va also pulled many of the pins and ground small grouves in them so the grease can flow to the outer ends a little easier...on mine the zerks are in the middle of the pin tube, not on the ends of the pins where they should be..
/ Grease Gun and a Screwdriver #11
Thanks for the info - never knew you could adjust them!
/ Grease Gun and a Screwdriver #13
Well, that's news to me.. But then again, I'm only 64 years old.
/ Grease Gun and a Screwdriver #14
James K0UA
Boy, do I feel like a bonehead. All these years and I never knew this. And, I have been having a b!tch of a time getting the gun ON the zerk. Now I know, duh.
THANKS GOES OUT TO KOUA.!!!!!!!!:thumbsup:
Edit; Now I go back to read the thread and find out....I am not alone. 49 years old and still have soo much to learn. TBN rocks.
/ Grease Gun and a Screwdriver #15
Wow, I thought, many many years ago, the adjustment was a nice find after having difficulty using it for only a few minutes. I can only imagine the unbridled excitement one would feel from figuring out how to use it after 30 years. And to admit to it publicly shows incredible depth of character. :D
/ Grease Gun and a Screwdriver #16
Wow, you have got to wonder how many have read this thread and now have a big flat spot on their forehead from going DOH!:laughing::laughing:
but they are keeping it to themselves!
James K0UA
/ Grease Gun and a Screwdriver #17
This is worthy of a "STICKY" don't ya think;).
/ Grease Gun and a Screwdriver #18
I nevr knowed that eithr....boy I feel tubid along wih the uthurs oning up to it.:thumbsup:
Tanks:confused2:
/ Grease Gun and a Screwdriver #19
I keep 2 grease guns on my service truck. One has a three jaw chuck and the other is a heavy duty 4 jaw. Both have the knurled collar to adjust "grip" on the zerk. I thought everyone knew.:D
/ Grease Gun and a Screwdriver #20
James K0UA
Fortunately, I had a flat spot on my forehead before I read this thread...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2023 Kubota Z232 (A60463)
2023 Kubota Z232...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
KJ K4020 40'x20' Carport Shed (A60463)
KJ K4020 40'x20'...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
