building a skid plate
/ building a skid plate #1
usmc5595
Does anyone make or has anyone seen a skid plate made for the 5103,5203,5303 or the 5403 two wheel drive models with a front end loader. I am looking to build or buy a skid plate for the tractor.
I want the skid plate to go from the front of the oil pan where the front end loader bolts up to the rear axle. It will need to be braced in the middle. I may brace it at the rear bolt area of the front end loader as well.
Thanks in advance.
/ building a skid plate #2
hi i have made a few skid plates for my 4x4 farm tractors 5 all together .they are made of 1/4inch steel plate cut the width of the tractor allowing for turning and front axle movement, welded straps on the sides with drilled holes to bolt grade 8 bolts to tractor where needed , works good only thing is you need to cut hole for oil draining , we built ours in our shop good luck
do you have any pictures of the builds?
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
2019 Kia Sorento AWD SUV (A61569)
2019 Kia Sorento...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
