336D Brush Hog
/ 336D Brush Hog #2
I have read that you should have at least 4 HP per foot of brush hog. I expect that is HP at the PTO. For example, I have a YM1700 with ~20 engine HP and 17 HP at the PTO. I can run a 5' finish mower great, but I understand that I shouldn't try to pull more than a 4' brush hog.
/ 336D Brush Hog
If that is true I am pretty well happy as I have 33 HP engine which I believe is about 27 HP at the PTO.
Mihg beable to do a 6 foot Hog. Lets see what other advice I get.
Thanks for your input.
Joe
/ 336D Brush Hog #5
I have used both a 5 and 6 foot rotary mower on my 336d model. They both would mow fine except in very thick, high grass where I could bog the engine at times.
I liked the 5 foot better as it was more the size of my rear wheel spacing, the 6 foot was a bit wider and presented problems if I mowed close to something and I would forget the extra width.
If you mow in tall, heavy weeds watch the radiator, it can quickly clog it up and overheat from the fuzz, seeds etc.
/ 336D Brush Hog #7
I have a similar tractor also and I have a 5' rough cut which I had on a 22 pto hp tractor previously and I dont even know its back there I mow in high gear up until I have a lot of turns to make then I slow down a little.
The rare times I do feel it I also see the smoke get darker and the tractor doesn't even slow down a bit. I think we could run a 6' but I know the 5' is no sweat at all and it fits the rear wheel track width perfect
CAT 315CL Manual Thumb (A68134)
CAT 315CL Manual...
John Deere 6200 Tractor (A64047)
John Deere 6200...
1995 Khronert 307 SS Single Comp 6,500 Gallon Insulated T/A Chemical Tanker Trailer (A68183)
1995 Khronert 307...
2020 Ford Fusion Hybrid Sedan (A66738)
2020 Ford Fusion...
340 GAL WATER TANK (A68842)
340 GAL WATER TANK...
2013 Mazda 3 Sedan (A66738)
2013 Mazda 3 Sedan...
