3-Point Hitch FORD 2000 DRAFT control SPRING REMOVAL
/ FORD 2000 DRAFT control SPRING REMOVAL #1
jaygeeoz
Ford 2000 diesel
Can anyone help me? Can the draft control main spring be removed by simply unscrewing the yoke as I need to replace a broken spring seat - if not how? If reassembly is to screw the yoke back in how do I judge what tension it should finish at as I have no fancy tools etc. Many thanks.
/ FORD 2000 DRAFT control SPRING REMOVAL #2
Unless the yoke was installed with some grease or antisieze, they can be hard to remove. they are internally attached to the lift control mechanism so you don't want to torque them externally because you'll damage something internally. Your best bet is to find a manual and see what you have to do to disconnect the inards before you try undoing the yoke.
2022 Landmaster EV (A64912)
2022 Landmaster EV...
CAT D6 Limb Sweeps (A68134)
CAT D6 Limb Sweeps...
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A67714)
CATERPILLAR C1.5...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Bush Hog 2615 (A64911)
